View full version: IDI Engine
  1. Kicking Over.....
  2. Injector pump rebuild/re-gasket. How hard?
  3. 89 jetta td
  4. Holset HX35 ! Who has made one work on their setup
  5. tapping into the exhaust manifold
  6. Crank nose fixing
  7. Post your intercooler setups
  8. can i get more power out of my 1.5
  9. it's alive!
  10. wastegate problems - what are my options
  11. rebuilding my '82 1.6 to TD, looking for advice
  12. What is max safe EGT? - 1.6td engine
  13. Hard Injector Lines......
  14. Manifold question
  15. Pump Project
  16. Turbo mod options
  17. 1.6td pump on aaz??
  18. Mercedes nozzles in VW injectors, possible?
  19. Pics of my 86 TD
  20. compatible bone yard N/A-Turbo pieces, ect...?
  21. VNT-15 exhaust side housing
  22. Some smoke okay on take off???
  23. Head Gasket help.
  24. What's the best place for engine rebuild kits?
  25. 1.5... upper limits & weak spots?
  26. The question from a new user
  27. K14 boost adjust???
  28. doka engine swap
  29. 89 jetta diesel NO START!!!!!
  30. 1.6TD higher performance build
  31. Clunking noise in deceleration?
  32. IP pump selection. Bosch VE or Cummins 4BT?
  33. Running on waste engine oil!
  34. 1.6TD Rebuild, or TDI-M Swap?
  35. Engine balancing
  36. Part of news
  37. + noise and vibrations on cold starts...
  38. 86 Golf Diesel 5-speed I lost my #1,#2,#5 Gears- Help Please
  39. removed injectors, bent the return barbs
  40. MK3 Jetta
  41. Plastic timing belt tensioner?
  42. AAZ Governer mod
  43. 2.4 6 cilindre engine
  44. any idea where i would find a linkage rebuild kit???
  45. my MPG is pissing me off now
  46. Where can i get a cheap EGT setup?
  47. Turbo wheel measuments
  48. What's the difference between the two?
  49. kkk k14 or garrett t2
  50. T3 on an AAZ
