View full version: IDI Engine
  1. New oil cooler seal? will it work?
  2. Motor ruined?
  3. 1991 1.6 crank/ 1981 11mm 1.6 crank
  4. has anyone raced there diesel in the 1/4 mile?
  5. Why do I still smoke so much?!
  6. New cold air intake design
  7. Injector Leaks
  8. Hybrid pump build in the small hours
  9. Bye oil, bye motor.. Now what?
  10. Help needed...mk3 aaz
  11. Long vs. Short Delivery Valves
  12. No power to glowplug bus bar
  13. Would 1.6 intake work on 1.9 head if ground right?
  14. EGT Probe in wastegate plate?
  15. well, i sealed the pump; but I put it together wrong and blew the head....whoops
  16. need help finding the right fittings for an oil return line
  17. Question about a Giles pump upgrade
  18. See if you can make sense of this problem...
  19. DIY VE pump test stand
  20. 1.6TD over heating
  21. Giles pump!
  22. rebuilding my 1.6 Turbo
  23. Designing a turbo kit for the IDI platform using aftermarket parts
  24. replace 1.6 with 1.6 turbo in 82 pickup
  25. 93 AAZ flywheel size
  26. What 1.6TD turbo do I have?
  27. Sharing: '83 Audi 5000 TD
  28. How to press in/out motor mounts on 1.6NA?
  29. Help: What order to assemble 1.6TD manifolds?
  30. 1987 jetta diesel 350,000kms
  31. Wiring Help, 3 Problems
  32. clear fuel line and fittings - sources needed?
  33. curious as to power potentials with 1.6L td
  34. 1.9 AAZ A/C TYPE ALT BRACKET'S 028-903-139 T ( New Old Stock )
  35. PUMP TO HEAD COOLANT HOSE ( 068121053 E ) 1.6 & 1.9 No Oil Cooler
  36. k03/ko4 talk
  37. My Jetta is Alive after being down a few months.
  38. The first electrical test on gasser to diesel swap
  39. my caddy 1.6d wont go into 5th gear
  40. Just converted a n/a to td
  41. new project
  42. EGT probe/ sealant ?
  43. Building a glow plug HOW-TO and need a couple of MK1 and MK2 pictures...
  44. B3 Eco-Diesel Glow Plug Controler
  45. 2.5" downpipe and 2.5" straight through exhaust....what can i expect?
  46. Angled oil filter mount
  47. Govener mod on this pump?? help needed.
  48. High EGT's, low boost, WTF?
  49. Boost Controller
  50. what did this come out of oil pump
