» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Upgrades for fuel economy
Build list
How do I build a powerful reliable TD?
KKK K24 Rebuild question
IP leak test
Oil coming out dipstick?
Tranny Wrestling
turning up boost will i burn more fuel?
just bought a new whip!!!
New to VW diesels
Temp Gauge
thicker head gasket and other mods?
td pistons
Fuel pump?
Trying to time without the right tools
Nozzles
how far is too far for advanced timing?
1.9 metal HG on 1.6
Petrol rings in TD motor~
Removing an Injection Pump
"resistance"felt when turning over
Quick Poll on injectors, 135 bar or 155 bar
Timing Belt and Tensioner
1.9 tD into a Vanagon
Air in fuel lines?
Front Brakes overheating will this cause any damage?
pre chambers not flush
Pros n cons of 1.9 and 1.6?
Leaky 1.6TD Injection Pump...
Look at what I got in the mail!!!
upshift light?
Bently manual on line?
1.9 TD pistons in 1.6
Head bolt removal?
Dyno day...
o2a tranny on a 1.6td
Methanol/water Injection Benefits for NA diesels?
harmonic balance pulley, necessary?
Diesel noob, starting problem.
Producing easy power from the 1.6 n/a...
No boost
1.6 NA cooling circuit diagram
starter bolts
What metal H.gasket for 1.5L
1.6TD camshaft in a 1.9TD?
metal / uprated headgasket
motor mounts
Will a 1.6 TD fit where a 1.9 idi was?
ghah!!
Is this crank forged or cast?
