» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Fitting turbo to 1.9D
fuel line question...
sources for turbo flange for 92 eco and more nozzle question
installing glow plugs in aaz
79 1.5 fun times
My 1985 Golf 1.6 N/A Build Thread - No 56k! Picture Time!
TDC mark slightly off
Something I saw and thought it wasn't for me
Does anyone know the difference between ABL and AAZ engine?
TD engine with N/A pump
injectors
Alternator bracket looks like ???
1966 Volvo Wagon with a VW 1.6 diesel & Toyota 5-speed
New ARP pro 2000 rod bolts for 1.6L VW
Speedometer info needed
replacement for K24 with ball bearing!
200mm flywheel on 210mm clutch disc..Possible?
New Irish member...AAZ inside...
Differences between cams
connecting rod dimensions?
show me your pumps...and 1.6 mechanical valve clearance.
AAZ valves?
Removing the crank cog bolt on ABL engine?and rebuild advice
WooooHooooo - Got a Diesel Cluster w/ Tach
1.6 Crank Trust Bearing Woes
1.6td questions.
new addition to the family
1985 Quantum 1.6td Where to buy Mahle coat pistons
1996 golf/rabbit pump and boost questions
The little wire near the alternator is???
K14 - K24 or (?) center housing swap
2.5 inch pipe
1.6 Oil squirters
Inside of the turbo intake log manifolds
water connection at cylinder head on aaz, anyone have 1?
Idle setting
Audi Tubo Diesel
1.6 IDI Waterjacket Improvement
glow plugs for my aaz?
AAZ oil pump ?
Tuning 1.9TD by using a hybrid turbo - A few questions!!
I think its dead?
Leaky injectors
running engine at high rpm's for a extended time
Electrical supercharger
Really quick question
Boost controller questions
i'm guessing this is going to be terminal?
how does this turbo map look?
What T- stat should I run?
