View full version: IDI Engine
  1. 92 EcoDiesel boils over
  2. more power
  3. Lost power on vnt15 1.6td?
  4. Narrowing it down...cold start issue
  5. One year later...
  6. Timing
  7. Is my pump timing retarded or something else?
  8. reading some old posts and found out the site has been redone before
  9. aaz building pressure in the coolant......STILL!
  10. smokey after rebuild
  11. glow plugs
  12. ~Mechanical 1.6td Custom built MLS head gaskets!!!~
  13. Lifter Interchange-ability
  14. new cam
  15. 11mm Mega head gasket woes
  16. --------How Much Fuel Is In A TD Pump?-----
  17. AAZ Delete or keep egr?
  18. idi for tdi???
  19. Factory 1.5TD engine
  20. boost pin/ blow off AAZ
  21. I put the DIE in diesel /Run-a-way damage?
  22. oil leak
  23. 1.6 mechanical block with 1.9 hydrolic cylinderhead.."V
  24. Does a tdi Alternator work for an aaz?
  25. Burning 10% hydraulic fluid
  26. beat the chssis with a big hammer
  27. CV Joint size?
  28. Tuning a bosch pump (lda type)
  29. Fuel cooling - optimal diesel temperature???
  30. differences in injection pump pulley wheels - 1.6 to 1.9
  31. TD rebuild
  32. Bought a turbo - VNT 15? Few questions?
  33. 11mm pump part number?
  34. electronic advance on AAZ pump - and joke LDA??
  35. IP for AAZ power enhancement
  36. size of hose on IP return line?
  37. Cold start lever?? Can I do without it?
  38. Driver's Door Glowplug "Myth"
  39. Heat shield reshaping
  40. 1.6L Oil Temp questions
  41. 1.6 Rebuild: Some Questions..
  42. Frankenmotor, well sort of....
  43. cooling issues!!!! advice
  44. I'm gonna turbocharge a 1.5 dont try and stop me
  45. Power steering rack..MKIII
  46. Camshaft or valve
  47. Parts help for 1.6/1.9 frankenstein
  48. Stock vw t3 turbo compressor upgrade
  49. Mega low budget IDI Engine
  50. 1.9 diesel test drives....
