» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
turbo idi pump on tdi block
Want to TD my 1.6NA
different diesel exhaust sounds/videos
PCV valve question
More Power!!!
Stiff engine
Best Diesel Conversion Kit for Vanagon???
Turbo Diesel - the best combination of parts to build?
MK1/A1 GTD instal pics?
high pressure fuel coming out return lines?
AAZ questions
I thought is was going to blow
Newbie needs exh~turbo bolt torques...
94 jetta instrument wiring diagram
Does anyone make a stainless downpipe for a 1.6 TD?
2.4 AAB questions
easy breathing intake for 1.6 NA
messed up...
GTD nozzle part # ?
Flow diagram needed
did a rather stupid thing......
what i did on sunday.
Cooling
installing 1.9 head on 1.6 TD block
TD oil
1.9TD crank sproket
Egr bypassing
Mk 1 TD oil cooler
Vacuum Pump Drive Gear Sizes
putting dry hydro head on engine, do I need to prime it?
electric fans
1.9 head on ebay
Exhaust on a 1.6 TD
N/A head Vs TD
Glow plug light idea
1.9 intake manifold...what can I use?
manifold leaking
1.6lTD long-runner intake manifold
manifold leaking
Injector Pump Question
Engine coolant thermos
Hello, I just bought my first diesel! Although I am not new
2 stage boost controller for pocket change anyone?2 STAGE!!
Franken engine
More Pintail Info?
piston to wall gap
chewed up oil pump tab in the power brake booster hole
i need a part number,,can someone scool me on this etkathing
broken turbo or something worse???
High rpm guys: anybody playing with cam timing?
