» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Do I need a water separator? Why are these things used?
AAZ pump is collecting air.
rebuild a diaphram type vacuum pump
Blown Head Gasket - Eh?
1.9 and 1.6 pics of crank combinations
Fresh rebuild; starts fine, then rough, then died...
Need a new block
Crud in intake manifold
Checking Clutch Disc Size and Wear
1.9l AAZ, stopping from hiway speeds, engine dies
Where to put a pyrometer probe in 1.6td
AAZ Oil pump - Vanagon - bow-tie/Diamond - exactly what engine do I have?
Peugeot TD pump parts to make EcoDiesel pump a TD pump?
AAZ into Mk 1
No questions, Just happyness
Eco Crankshaft Pulley
Smokey AAZ!
Quick brainstorm on 1.6TD no power issues
Notch dimensions for piston oil squirter relief?
Bore and crank dimensions - AAZ rebuild
MK1 people: Need some pics (important)
1.6TD vs AAZ fuel economy
Source for AAZ/TDI K03 Turbo Outlet Flange
starter solenoid terminal snapped, almost stranded
cruising boost
Turbo Size for a 1.6TD...?
weird boost problem
Moving a kkk14 away from intake - AAZ 1.9 . . ?
Auto transmission into 91 jetta na
Cam plate and delivery upgrade
1.6td injector pump timing help--Anchorage AK
G-Teched my 1.6TD - Part 2
1.6TD T3, stripped the 12mm 12pt?
turbo mount bolts
High RPM stalling problem
ADA pump installed on ECO motor
More questions about pulleys ...
Help needed - mounting parts for the 1.6 TD injection pump
How does lower compression affect performance?
Scored Piston and barrel - 1.9 AAZ Vanagon
more aaz 1.9 td problems.
Vacuum pump oil leaking / spraying everywhere
Every injection part ever
See here Aki76's garage and his wife's daily Jetta!
Replacing Exhaust Manifold Gaskets - Any Tips?
Exhaust Manifold?
Boost dropped off
aftermarket gauge sensor questions
setting idle
