» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
AAZ Glowplug Replacement
question about my turbo
aaz 1.6td head cross over questions
Injection quantity bushing (internal IP)
1995 jetta coolant gasket
help needed reassembling pump (im an idiot) (UPDATE)
Aircon retrofit?
Mystery connector on dash
1.6TD Megabuild
Another IP question
IP too far advanced timing symptoms
Anyone have any pic of an aaz motors coolant hoses Vanagon?
toyota td
Low oil pressure diagnosed, question on main bearings
Glow plug relay WTF
94' k14 turbo actuator
81' GTD CY glowplug questions again, is there a temp sensor
Rod studs
81 CY 1.6td Broken Glow Plug tips 3 tips are broken, some
auto TDI starter on 1.6 020 tranny....
Crank case venting idea?!?!?! opinions needed.......
NA.....now a TD w/ some pics
Head Temperature?
Do my injectors need an overhaul?
IP rebuild by Giles - All done... WOOOOWWWW
LDA - valve is dripping diesel....
T3 Replacement Turbo ????
Which Head to Use ?
Main bearing question
Tranny and diff oil change questions...
Intermitant Battery Light. Bad alternator?
What oil do i use?
Piston to cyl clearance
1.6 oil return line fittings?
More IP pump woes...
Kind of a Dumb Question
Will this head work??? Please Help
Please help! Stuck with re timing VW 1.9TD - ABL engine code
Finally got my Guide
1.6 diesel altenator needed in Calgary today
AAZ head 8mm valve question (woohoo thanks guys!)
need some vanagon pics
91 motor swap with an 87 ?
return line
question about fuseboxes
1995 Jetta 1.9L TD
Those of you who have made a new oil return line
Brand new AAZ head precup peculiarity
max fuel screw base setting
1.6D Cam - Same As TD?
