» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
"electric" aaz pump...want to simplify!
Lubricant Gobbledegook
Anyone here promoting or running the 19:1 CR philosophy?
02a swap question
Two evil bolts on the crankshaft pulley
very irritating
Head Gasket Preload
PD Crank into 1Y??
Darth Garry Apprentice Training...
varnish in ve bosch pump
Full Load Adjustment Screw
WVO & Injector breaking pressure
crack in block?
Is a leaky IP hurting things? or is it ok to run for a while?
Turbo calculations and compressor maps
IP swap question
2nd ring on a M21D24 piston
No cooling system
Rings?
need new head........
Governor differences on NA vs. TD pumps
TD Exhaust manifold flip on A2: Not possible
Auto trans rebuild/hop up..
Fastest Nozzle change and GP check - for 8v-of-fury ;)
GTD into a corrado?
AAZ Build Up
t2 turbo indexing
Oil in the intake 1.9 td
Idling issues and EGR vacuum pipes.
Cold Start Cable Problem
PD150 INTAKE ON A 1.9 AAZ ??
part number of rubber valve cover gasket for 1.6 engine
Where can you buy heat shields?
turbo head vs. non turbo head
TECHTONIC'S TUNING DOWNPIPE 1.9 AAZ 2.5 ' VW MK Caddy
Minimizing smoke
Resealed my pump.
1.6TD issues.........
question about which IP to use, aaz to mk1 swap
mk3 AAZ clutch slip - advice please
IP timing question
Injector pump shaft Bolt
Oil feed line size
Stripped feed pump cover screws while disassembling injection pump..suggestions?
Oil temp/pressure senders - fit?
Clutch failure
best exhaust setup for turbo sound?
VNT17 Fitment, pictures.
Has anyone done a N/A >Turbo 1.6 write up???
Tuning mk2 1.6 cl td HELP
