Author Topic: PD Crank into 1Y??  (Read 2133 times)
August 12, 2009, 12:53:58 am
ryanp
  • 269
PD Crank into 1Y??
« on: August 12, 2009, 12:53:58 am »
Is it possible to fit a PD crank into a 1Y diesel (that will have a big blower attatched!!) to get rid of the crappy crank pulley. I know the AHU/1Z crank fits but i'd like to go a little further.
Would the rods fit too?
Cheers!
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #1August 12, 2009, 04:55:14 am
rabbid79
  • 684
Re: PD Crank into 1Y??
« Reply #1 on: August 12, 2009, 04:55:14 am »
Not sure about the main journals, but the PD crank will have larger bearing journals than the 1Y.  That means you will have to use PD rods.  However, the PD rods will have larger pin ends than the pistons in your 1Y (25 vs. 24mm) or something like that.  Also, the PD crank has a sprocket built into it for running the chain driven oil pump.  In other words, it would probably be more trouble than its worth.  You could either convert your crank nose to accept the newer style pulley, or use a friction washer between the standard pulley and the crank nose.  These are supposed to make all the difference.
« Last Edit: August 12, 2009, 05:22:14 pm by rabbid79 »
'15 WRX
Reply #2August 12, 2009, 08:38:10 am
GEE-BEE
  • 1604
1Y??
« Reply #2 on: August 12, 2009, 08:38:10 am »
What is a 1Y motor ?
Iam in the U.S. and I have never heard of this type...
Thanx for the reply
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3August 12, 2009, 10:20:17 am
« Reply #3 on: August 12, 2009, 10:20:17 am »
its a european TDI engine. we never got them.
Reply #4August 12, 2009, 10:35:56 am
« Reply #4 on: August 12, 2009, 10:35:56 am »
oh yea huh? my bad, im so not even close to awake yet, just got out of bed a few minutes ago. was up late last night building boost controllers. the 1y has that ***in intake that looks similar to a gasser one right?
Reply #5August 13, 2009, 11:18:31 am
ryanp
  • 269
« Reply #5 on: August 13, 2009, 11:18:31 am »
Would the best upgrade just be a crank from an AHU then without massive machining?
I'm just looking at building a nice strong engine on a low budget as i've never built an engine myself!
The 1Y intake is sweet!
Thanks
Ry
