» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Voltage Regulator?
Boost How much?
Has anyone re-used factory 12mm stretch bolts?
Many Questions.......1.9TD (AAZ) Engine code
bucking bronco
Lighter flywheels?
Exhaust manifold for K03 turbo
lowering compression
Glow plug fusible link on firewall
Boost Pin?
Timing selenoid question???
1.9D in Caddy (like Rabbit I) 1.6D?
Pump timing range
using 1.6TD garrett turbo on a gasoline engine?
86 Golf Diesel questions
what turbo does the 1.6 TD use?
What kind of hp and tq do you think I am running?
which turbo?
injector lines for a 91' eco diesel
boost gauge install problems
where do you mk3 td guys put you IC
Attention anyone rebuilding an engine: MAIN BEARING FAILURE
Injection pump upgrade. Which one ?
anyone ever build home made propane injection kit?
More fun with the video cam (burnout video + in-car)
Turbo Upgrade: 93 Passat 1.9L
Injection pump woes
What is a Turbo Injection Pump worth?
Intake Cleaning?
1.9 TD
Finally got the Quantum apart. Lots of pics.
88 TD oil consumption
Mixing & Matching Parts?
Any info on this pump?
1.9D performance gain question
Wastegate Problems
oil light/buzzer
Intercooler going in
1.9TD pump. Leaking between the head and the housing.
cheap injectors and heat shields - 1.6 turbo diesel 88 Jetta
1.9td -- injection timing
Stock fuel filter
Crank Case Control Valve
Idle RPM
Help needed: pump operation/theory question
A little problem
33MPG!?!? WHat gives??
eco diesel swap into my 86 golf?
Engine pings
boost indicator?
