View full version: IDI Engine
  1. Cam regrind... for efficiency?
  2. Pic Request: crank snout fix
  3. Exhaust Downpipe
  4. Need help to make my car run low mpg, and another problem
  5. noise control
  6. coolant light
  7. dont you just love it when......
  8. easy to change cam plate in fuel pump? which one to get?
  9. VNT-17 or VNT-20 or something else? 1.6TD buildup...
  10. Mobil1 5w50?
  11. Buying a Golf Mk3 GTD (1,9TD)
  12. Intercooler questions
  13. Intercooler location
  14. Vacuum Pump
  15. 3.67 Final drive on a 1.6TD
  16. hilshy n/a swap out/td swap in.
  17. Can you add an aneroid to a normal 1.6 pump?
  18. Ideal Timing Number???
  19. Golf III IDI
  20. Should I be upgrading my clutch?
  21. Has anyone measured cam lift and duration?
  22. jx (T25) pump on a AAZ
  23. Rabbit Rebuild Kit?
  24. Tuning the 1,6 TD
  25. 1.6 td has no power
  26. About to get a diesel
  27. Piston top Mod?
  28. AAZ 1.9 TD manifold upgrade
  29. Help with KKK turbo ID please
  30. A1 factory tach again,.....
  31. Engine rebuilder in Vancouver B.C.
  32. Piston Projection Question
  33. Just got the FS-2500 filter in today!
  34. Converting my 93 TD Transmission to TDI 02a
  35. is a diesel fusebox the same as a gas?
  36. 1998 1.9D Smoke from 1800 to 2200 RPM, then runs perfectly..
  37. injector pump rebuild?
  38. A hot day, and I didn't overheat
  39. How do I tell if my turbo is working?
  40. crank pulley question
  41. I got my TD started! Small Issue though..
  42. Would 11mm size bolts head fit on a 12mm block??
  43. New here, but not to diesels
  44. internal pump pressure
  45. rings from bottom?
  46. Lifter questions.
  47. Stripped engine mount bosses
  48. possible to use 1.9 pistons?
  49. Making more power from a 1.6 non turbo
  50. crankcase vent hose question
