» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Building my own hybrid
California laws
calling scopefrfd
busted wastegate or tired turbo?
Calling jimfoo
1.9TD Doka
I think I figured out the blow by...
Another Weird Idea...
so confused about the boost pins!!
.40 over sleeves
For IDI fans...The AIR-COOLED diesel beetle prototype
1.6td connecting rods, polish and peen or h-beam? Pictures!
pump different from FAQ pic?
running pros
Welding Cracked Head
max boost pressure for a k03 turbo
k03 to k24 can i leave my fuel alone? 1.9 AAZ
tdc marks on flyweel
1.6TD in a Mk3?
leaky IP throttle seal
does anyone have the part # for turbo flange
Kind of A Dumb Idea....But I'm Intrigued
Turbo names?
volvo ecodiesel project
setting thrust bearing end play?
Injector Nozzle Theories
Rebuilding a 1.6
1993 TD jetta tranny ratio?
newbie question
85 NA Jetta, flashing temp ligt and alternator/battery light
Anyone have a mk2 NA with a AWY tranny?
Just blown my turbo!
how many feet should i get
what are the best injectors?
putting the K24 instead of my K03 better fuel milage??1.9AAZ
Just finished rebuild, does this sound right
Extreme 4x4
Lightening a 210mm flywheel+16v 2.0 pressure plate questions
head bolt question
td intercooler
Dumb governor question
Replace oil cooler seal.
retrofit Oil Pan Gasket with Baffle? Do I need one?
have 1.9 AAZ i got a 1.6td manifold and KKK24 turbo easy swa
Boost levels from your stock or modded 1.6 TD
Turbo oil line part# needed
Just bought a high milage 95' Passat TD and looking for info
Electircal problem with me 95 passat wagon TD
Lopey Idle
Miss during cold starting
