» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Understand Compression results
1.6td (where is everone getting them)
1.6 vs. 1.9 how to tell which is which.
45 trim t3/t4?
Stock smoke setting?
AAZ engine in a Passat 95, fuel cuts off at 2900 rpm
The most powerful 1,6 TD
1.6TD oil squirter location
My Mk1 1.6TD build...lots of pics
1.6 issues.
mercedes injectors?
Cold start choke
Fixing accelerator pedal jolts
Intermediate Shaft Bearings/choices...
How do you know if you have the fast glow plug relay?
Just bought a Garrett VNT 15 from ebay
Transverse/Longitudinal differences
searching for Vanagon JX injectors in the USA
ADVICE ON STARTING ISSUE
Which injectors should I use?
Rabbit TD in America
ran her dry by accident
1.6 wiring questions
1.6 and aaz valve cover gaskets the same?
questions and opinions on a TD setup
water pump question
Injector Difference? ECO vs TD
Trying to rig a button for the glow plugs
Engine temperature?
Radiator Compatibilities
part numbers for 3 piece bearings?
Foamy Diesel
1.9AAZ + straight pipe... TOO LOUD!
mech 1.6TD headgasket woes
It's running great, thanks for the help!
AAZ. Injection pump. 2 solenoids???
first time with timing tools
Malone's 1.6/1.9 Frankenmotor
differences in the ECO 1.6TD and the regular 1.6TD?
1995 B4 glow plug relay timer location and timer duration
Oil pressure guage
pug 306 td injectors in a 1.6 td vw
IDI Year/Model Breakdown?
Pics of my new ride.
'81 Rabbit not starting
AAZ Crankcase vent
Pressure in 1.6 NA cooling system
Pump timing advancement: How To?
Anti-DIy turbo rebuild
Proportioning valve on ABS cars?
