View full version: IDI Engine
  1. possible lack of oil to head in 1.6??? worn out lifter bores
  2. Timing belt problem
  3. Replacement engine mounts
  4. Temperature issues
  5. fuel gets cut out easily when it's nearing an empty tank
  6. Idler Pulley
  7. smoke plus no rev
  8. Intake Modification
  9. A/C pump in MK1 Rabbit - AAZ convertion
  10. Any diesel gurus in the Sacramento area?
  11. surge
  12. alternator w AC needed
  13. Head Gasket Question
  14. head question...
  15. blkboostedtruck LOOK HERE!!!!
  16. getting horrible screach during start up !!video!!
  17. 1.6TD head milled.0009
  18. Exhaust manifold gaskets and porting
  19. t belt broke
  20. Rabbit diesel missfires a little after warms up.. hmm
  21. New Member with cold starting & smoke issues
  22. Funky Idle
  23. AAZ Dampner Wobble ( Pulley )
  24. Big Valve 1.6 Head
  25. piston oil jet cooler
  26. Air to Water Intercooler, lets see em!
  27. Leaking return lines
  28. engine orientation questions.
  29. Eco or normal 1.6 turbo engine?
  30. Injection Pump Tuning
  31. top speed problems
  32. The difference in pumps
  33. seeking rebuild advice regarding minor worthy mods
  34. IDI engines: fuel economy comparison
  35. Meth injection
  36. Gearing
  37. Air Filter opinions
  38. Mysterious reservoir.
  39. Converting 1992 1.6 TD with A/C to serpentine belt drive?
  40. 11mm Head Studs
  41. couple of questions
  42. Rev hang after WOT pulls or any mid to high RPM's
  43. Did all GTD's come with a 210mm clutch?
  44. Are Bosios worth it for a 1.6NA
  45. Garrett GT-15 for 1.6TD?
  46. Is this the Blow Off Valve?
  47. Pushing water out of reservoir, and vibration in cab
  48. About the VNT
  49. Newer MK3 tach issues
  50. hi rev sputter
