Author Topic: piston oil jet cooler  (Read 3661 times)
July 25, 2010, 04:16:31 pm
quasi
  • 26
« on: July 25, 2010, 04:16:31 pm »
I am putting my engine back together.  Do I seal the oil squirters with anything when I slide them down inside the holes?  I was going to use "Loctited red" for the screw, but what about the shaft itself of the jet coolers that slide down inside?
This is for a CY Turbo diesel engine
1981 VW Caddy
1984 Saab turbo
1974 1/2 MGB-GT
Reply #1July 25, 2010, 04:46:35 pm
Re: piston oil jet cooler
« Reply #1 on: July 25, 2010, 04:46:35 pm »
were they sealed before?
Reply #2July 26, 2010, 01:54:57 pm
quasi
  • 26
« Reply #2 on: July 26, 2010, 01:54:57 pm »
Thanks for the replies and answer.  :)
1981 VW Caddy
1984 Saab turbo
1974 1/2 MGB-GT
Reply #3July 26, 2010, 10:32:09 pm
rodpaslow
  • 670
« Reply #3 on: July 26, 2010, 10:32:09 pm »
I've used the red -copper RTV and it works as well.  Just a note, if you're used to gasser vw running mostly at about 60 psi at highway speed, the oil squirters and turbo take a bit extra oil and drop pressure to about 35 to 40 depending on oil & temps.  At idle about 7 - 10 psi.  If there is no sealant between the squirters at normal engine temperature there is no oil pressure.  I've had this happen in my younger years.
Reply #4July 27, 2010, 04:19:21 am
« Reply #4 on: July 27, 2010, 04:19:21 am »
good to know!
Reply #5July 27, 2010, 12:34:03 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #5 on: July 27, 2010, 12:34:03 pm »
That's why the turbodiesels had broader oil pump gears?
Reply #6July 27, 2010, 12:53:35 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: July 27, 2010, 12:53:35 pm »
What is this about? I just cleaned mine up and re-installed with locktite red...
did i forget something??? I didn't notice anything else in their composition.
