View full version: IDI Engine
  1. Mazda Intercooler
  2. torque plate honing for vw block? never heard of it? READ.
  3. Possible to find .38 AR turbine housing w/ standard T3 flang
  4. Boring GTD-AAZ nozzle question.
  5. (more) intercooler questions and Hybred K26/K24
  6. interesting...........
  7. Which boost controller?
  8. What exhaust size and brand for 1.6TD
  9. GTD intercooler
  10. GTD Nozzles VS. Stock TD Nozzles VS. Stock NA Nozzles
  11. Glow/Heater Plug Removal.
  12. Max rpm on a 1.6td? [New mods coming]
  13. Garrett turbo q's??
  14. Max advance for diesel, will it ping?
  15. Intercooler FMIC into A1 Caddy (56K beware)
  16. Clutch/Transmission Identification
  17. 200hp in Azz enigen
  18. 91 jetta versus 2002 wrx
  19. Intercooling
  20. turned some screws.... EGT's?
  21. Oil Pan Baffle/Gasket
  22. DIY Boost Controller?
  23. crank AAZ
  24. Quick Q on fuel pump brackets (1.9 pump on 1.6)
  25. Engine meltdown warning...
  26. Are mk1 and mk2 exhaust manifolds the same?
  27. Lightened flywheel and stretch bolt questions...
  28. 1.6L TD or 1.9L TD ?
  29. 1.9 Crank Question
  30. 2000tdi bottom end rebuilt to use with a 1.6 head?
  31. Found a 2.4 diesel engine in the j-yard
  32. Any idea on aprox HP my 1.6TD will have
  33. Everyone's dream
  34. GARRETT TURBO?
  35. g60 valvecover on 1.6TD engine
  36. 1.9 TD Turbo Upgrade Questions
  37. Casidiam?
  38. computerized rev limiter fuel shut off? I got a plan.
  39. who else does pump mods?
  40. Wastegate adjustment question
  41. low-tech conversion of twin-scroll housing to VNT turbo?
  42. ABA and AAZ ???
  43. Block/Head mods for strength, longevity, and of course HP.
  44. Boost Adjustment on KKK Turbo
  45. 1.6 Mech TD head part #'s
  46. Engine Rebuild kits?
  47. How Can I Get The Most Out Of My 1.6L TD Engine?
  48. Will a 95.5 mm crank fit in a 220mm block?
  49. Wastegate line restrictor
  50. Using a old IP with dual stage injectors??
