View full version: IDI Engine
  1. Tranny question.
  2. Weird engine Squeal help?
  3. Measuring internal pressure
  4. 1.6TD vs. AAZ pump
  5. Turbo setup?
  6. what turbo aaz
  7. Timing up 1.6 pump on 1.9 engine! Need a pulley too!!!
  8. 1.6td Not starting - no fuel
  9. IP timing problem.
  10. Good price for a complete AAZ w/100k on it?
  11. anyone running Greddy profec-b boost control?
  12. The Best twin turbo set up?
  13. Are the Pressure plates the same on the 1.6L's as they are on the 2.4L & 2.0L's?
  14. Quick question: about the passenger motor mount when swapping an AAZ into a MKI
  15. First time injection pump removal
  16. Passenger intake - what does it look like INSIDE
  17. clutches
  18. A few pump questions.
  19. '91 Jetta 1.6 na timing belt and water pump replacement Q's
  20. '91 Jetta 1.6 na coolant temp gauge not working
  21. 1.5L pump on 1.6L
  22. which is better, K14 or T2?
  23. I want my own 2.1AAZ.
  24. To adjust the wasegate preload setting or not T2 turbo
  25. on to the next.... 82 Diesel caddy...
  26. temp gage going to hot and glow plug coming on after starting
  27. Cold weather & car wont start and a couple other q's everyone take a look please
  28. strange faillure after boost surge
  29. Caged and Uncaged Governors, a Mystery to most it seems.
  30. b3 Passat AAZ won't start after dead battery and alarm HELP!
  31. grabby on takeoff
  32. Return spring?
  33. TB tensioner, up or down?
  34. "T" hose coolant leak
  35. best piston ???
  36. '91 1.6 NA (with alt. comp.) into '91 eco diesel body--starting problems
  37. AAZ Silicone Engine Coolant Hose Assys
  38. DIY dry sump?
  39. building first TD. newb needs direction
  40. The Governor Mod - Clarified
  41. ABA intake manifold
  42. kkk VNT
  43. 1.6 wont start again....
  44. power steering pump
  45. PD150 on AAZ pics
  46. Correct oil 1.6td?
  47. What ARP studs do I need?
  48. so when do we get these modified to fit our cars
  49. WRX top mount intercooler?
  50. Installing power steering on an economy AAZ?
