View full version: IDI Engine
  1. Well that's a first...
  2. 11mm block, AAZ head?
  3. 1.6 N/A With 1.6TD Tans.
  4. Intermediate shaft -- OK to turn if timing belt is off?
  5. Adding a PCV system to my homebrew 84 GTI 1.6NATD
  6. K03 Mounting Bolts and oil return gasket
  7. egt wire splice
  8. no fuel out of pump.what can cause this?
  9. Question about threads/pitch on oil filter manifold ?
  10. Seeking Part Number - Front exhaust pipe Golf GTD
  11. Franken Engine.. Tips/advice/pointers needed/welcomed
  12. Setting timing on engine stand
  13. Sealing paste for oil spray nozzles. What is it?
  14. AUG longevity?
  15. Leaky and Injector Blow by 1.6TD?
  16. AAZ year made by serial number?
  17. New 82 Vanagon Diesel, ran out of fuel.. issues arised.
  18. Will the interior from 79 Dasher wagon fit an 82 Quantum wagon??
  19. TD: Block oil drain?
  20. Air bubbles in Injection pump feed line...
  21. The old blue rebuild (1983 1.6 TD)
  22. Blown oil seals, upgrade to VNT?
  23. By passing the air compressor.
  24. injection pump top cover seal replacement
  25. How the hell do you get the camgear off???
  26. What exactly is a GTD?
  27. Why is my mileage so much lower than others claim?
  28. weird oil pressure behaviour
  29. K24/T3 turbo on AAZ
  30. Diesel Troubles, can't start (86 td jetta)
  31. Internal IP pressure specs
  32. thread locker vs. antisieze; silicone vs. gasket; freeze plug sealant
  33. Found new AE prechambers
  34. Where to get a set of Injectors Pop Tested near Seattle?
  35. 11MM ARP studs for my old 1.6?
  36. k14 highway psi
  37. What's Up, Doc?
  38. ARP thread corrosion
  39. Break in and head bolts
  40. Gas leak on top of IP
  41. Flushed brake fluid- what about the clutch?
  42. Looking for someone with IDI timing tools around Abbotsford, BC
  43. VE pump accelerator shaft O ring size
  44. 1997 jetta tdi or idi?
  45. k16-2467, possibly the best turbo for a 1.6
  46. Differences between early 80's and late 80's 135bar N/A Injectors
  47. A Milestone for the Eco in Florida
  48. Blown pump seal-runs fantastic!
  49. 107a or 109 pump- specs? / which to use?
  50. MOAR POWA
