Author Topic: 11mm block, AAZ head?  (Read 3257 times)
December 15, 2011, 03:20:29 pm
monomer
  • 414
« on: December 15, 2011, 03:20:29 pm »
Is this possible? I think all aaz's made are 12mm.
I have blocks for each, just wondering if it'll bolt upto the 11mm block thats in the car.
www.michiganvw.org
Reply #1December 15, 2011, 03:49:30 pm
Mark(The Miser)UK
  • 1557
Re: 11mm block, AAZ head?
« Reply #1 on: December 15, 2011, 03:49:30 pm »
I think the issue is using an AAZ head as part of a search for more power. 11mm blocks are a source of inherent  weakness.
If your 12mm block is hydraulic, then your AAZ is a direct fit. Otherwise work to do....
« Last Edit: December 15, 2011, 07:54:37 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #2December 15, 2011, 04:34:01 pm
monomer
  • 414
« Reply #2 on: December 15, 2011, 04:34:01 pm »
I think the issue is using an AAZ head is part of a search for more power. 11mm blocks are a source of inherent  weakness.
all are mechanical, from what I can tell. The one that came in the car is a 12mm, but it's disassembled. The one that's in it now is 11mm from a 79 rabbit.
One block is fully dressed and has lived in a trash bag for years, no idea what it is.
www.michiganvw.org
Reply #3December 15, 2011, 07:40:45 pm
« Reply #3 on: December 15, 2011, 07:40:45 pm »
if its an 11mm engine from a 79 rabbit, and its ORIGINAL, then its a 1.5D, and you dont wanna really mess with one of those in the quest for more power..
