» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
1.6TD intercooler piping diameter
Just removed my head...
Water Injection
Progress
now the thing won't start!!!! help?
noob with questions
Fuel heated through IDI pump return?
Vw's 1.5l experimental TD
Where to find downpipe flanges?
Intercooler???
Quick size question.
Glow Plug Fusable Link Alternative ? Help
removing sending unit
Intercooler Pics!!
Timing Belt Snapped... How Much Damage?
Overfilling Oil in a 89 Turbo Diesel
Oil filter conversion kit
AAZ lightening
1.6 crank on 1.9
Exhaust manifolds
Cant get car to idle right after gov. mod.
Gonna remove AC compressor
1.9 cap bolts
oil pressure sender
Vacuum Gauge for fuel line
missing spring?
ARGH! Where can I get a governor shaft NUT! NEED HELP!!!!
Not Air bubbles-- Again
banjo fittings question
making my 1.9td faster
Fram Air hog? opinion/experience
Boost Gauge Problem Inaccurate Readings Please Help
Cam pulley: red loctite or blue?
10mm tdi Pump head Timing plug, can't set timing
Questions on AAZ performance and installation in a Caddy
Need help!!! Throttle return springs/linkage.
I want to start playing now.
Looking for 1.9 TD glow plugs for a good price
Post turbine exhaust gas temperature on 1.6 TD?
Timing belt broke - help!!
Headgasket Mod question
soaking injectors in acetone - good idea?
how much torque does it have?
Max Fuel Screw Help
Gov. Mod. = better mileage???
oil pressure starting up a new rebuild
Cam shaft pulley: really need help!!!
Boost Controller Install In 91 Eco-Diesel KKK-14
pump and injector rebuild for Giles
new mod, highly recommended
