» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
canadians what oil you running in your TD?
1.6lTD Garrett Turbo disassembly
1.6 bent valve? mechanical head
alternator belt replacement-help
diesel battery?
IP with 10mm pump- help timing
I need a little help..lol
IP Leaks only when Cold? Shaft Bushing Gone?
valve shim question
Injector calibation shim group buy
What happens to oil warning system when W tach not installed
TD Van oil return woes
D24T(ic)
Best spot?
V Belts? Contitech or Gates? Preferences?
Changing Thermostat
N/A diesel turbo questions...
Totally exhausted.............
Installed boost gauge now I need to do EGT and boost control
self adjust clutch problem
Can't hear K03?
alt. pulley
convert my ecodiesel to true TD
how do I block the 2nd oil drain in a hydro head?
boost gage anyone try this one?
Water pump pulley
Giles pump for an N/A motor
Wet nitrous tank
bb
my battery wont recharge
Interesting article-ceramic coatings
torque spec for injectors?
ADJUSTABLE BOOST COTNROL SCHEMATIC
Down pipe
Turbo balancing
Way too much smoke - how to fix
how fast
LDA INSTALL
oil feed and drain ok if not vertical?
glow plug trouble
Bottom end rebuild...
getting the alternator belt off!!
IP's interchangeble?
Turbo for 1.9
Where to put pyrometer
What is it?
electrical switches on IP?
1.5TD first start
Degreeing the cam in
What is it?
