Author Topic: D24T(ic)  (Read 2818 times)
January 02, 2008, 08:14:03 am
Flying Scot
  • 2
D24T(ic)
« on: January 02, 2008, 08:14:03 am »
i have a Volvo 945 SE DTic and i am looking to get some more i.e. lots more performance from the engine is there an easy 1-2-3 way to go about achieving this?
thanks in anticipation
thanks
kindest regards
David
Reply #1January 02, 2008, 12:26:55 pm
rabbid79
  • 684
D24T(ic)
« Reply #1 on: January 02, 2008, 12:26:55 pm »
Hi, I'm not familiar with that particular model of Volvo.  Since you posted in the IDI forums, I'm going to assume its one of the older VW 2.4L inline-6 engines.  In that case, practically everything you can do to the 4-cylinders, you can do to the 5 and 6-cylinders.  The first few things you could do are turn up the fuel on the pump, fiddle with the wastegate on the turbo for more boost, and add an intercooler.  Of course, you could also modify the governor in the pump for more high-end power, add bigger nozzles, and a free-flow exhaust.  It would be wise to add boost and EGT gauges as well.
'15 WRX
Reply #2January 02, 2008, 02:27:27 pm
Otis2
  • 191
D24T(ic)
« Reply #2 on: January 02, 2008, 02:27:27 pm »
There are several threads about that engine here.
Search the "Non-VW Group Diesel" section from the main forum page.
Reply #3January 02, 2008, 03:04:56 pm
D24T(ic)
« Reply #3 on: January 02, 2008, 03:04:56 pm »
from what i know u can really make those cars coot along, if i found one i'd buy it real quick like.
Reply #4January 02, 2008, 03:55:36 pm
Flying Scot
  • 2
D24T(ic)
« Reply #4 on: January 02, 2008, 03:55:36 pm »
Quote from: "rabbid79"
it is the VW 2.4 TD with intercooler.
thanks
kindest regards
David
Reply #5January 24, 2008, 07:13:29 am
Eli
  • 17
D24T(ic)
« Reply #5 on: January 24, 2008, 07:13:29 am »
I refer you to this thread:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=645
Basically everything carries over from the 1.6 to the 2.4
Best of luck,
-E
How fast?
As fast as it takes.
