View full version: IDI Engine
  1. Tensioning the Timing Belt Correctly
  2. Duff injector pump?
  3. Injector re and re questions...
  4. Timing 1.6l ?
  5. egt gauge
  6. Fuel cut solenoid question
  7. Problem with 1.6td install in vanagon - wastegate in the way
  8. TD drop-in
  9. Injector heat shields
  10. aaz crank
  11. Metal head gasket for 1.6TD?
  12. need new exhaust
  13. mpg L/100km gauge
  14. clogged return line
  15. Tranny Oil?
  16. Using SF oil?
  17. I wonder what it does.
  18. mk2 head bolt replacement
  19. lda spring
  20. Connecting Rod Stretch Bolt Replacement?
  21. Can you recommend a diesel compression tester?
  22. Injectors for sale
  23. 91 Jetta TD surging?
  24. Piston Cooling nozzels?
  25. return lines leaking...
  26. put my new inj. pump in
  27. adding a turbo to a non turbo engine
  28. Clutch Question
  29. Well its legal, time for more power
  30. Crank scraper???
  31. Starter woes! (Pics) (Solution Found)
  32. Power steering pump bypass mod
  33. ok I want 15 sec in the 1/4
  34. Fuel pump(s)?
  35. mechanical valve adjustment
  36. rain tray cold air intake
  37. Are there any 12mm head studs available?
  38. Water Temp.
  39. 4-speed/5-speed swap
  40. A1 turbo diesel engine swap troubles
  41. Convert a 1.6 n/a block to turbo?
  42. is an automatic bay tranny compatible with a diesel
  43. Question about dial gauges
  44. Thinking about modding the pump
  45. injector part numbers
  46. pics of IC install in B3 passat
  47. My angry engine
  48. need help with injection line routing
  49. Cool Air intake
  50. well I supose this isnt engine but...
