Author Topic: Problem with 1.6td install in vanagon - wastegate in the way  (Read 2594 times)
March 09, 2005, 02:15:38 pm
RichMason
  • 10
« on: March 09, 2005, 02:15:38 pm »
Greetings,
I am in the process of converting my gas vanagon (84) to diesel by installing an 85 Jetta 1.6td engine.  I have the proper quantum exhaust manifold and a complete 82 diesel vanagon for the other parts but the wastegate on the turbo interferes with the intake manifold.  How have others fixed this...can I just remove the wastegate?
Thanks,
Rich Mason
Reply #1March 09, 2005, 02:31:18 pm
VWRacer
  • 649
« Reply #1 on: March 09, 2005, 02:31:18 pm »
That doesn't make sense to me. On my Quantum, the wastegate is under the turbo, while the intake manifold is on top of it. Can you explain further?
Thanks!
Stan
C-Sports Racer
Reply #2March 09, 2005, 05:50:34 pm
VWRacer
  • 649
« Reply #2 on: March 09, 2005, 05:50:34 pm »
Rich, here's a photo of the turbo setup on my Quantum. The hoses have been removed to show the turbo and manifolds. The compressor section of the turbo is a bottom center (the oily looking round thing is the compressor outlet). The wastegate sits tucked up against the block a little below the compressor section.
Above the compressor section sits the EGR valve and associated plumbing (tube running to the right with a bellows segment). This may be what your post refers to. If so, this can be safely removed to make room, like shown below.
Stan
C-Sports Racer
Reply #3March 26, 2005, 05:28:52 pm
RichMason
  • 10
« Reply #3 on: March 26, 2005, 05:28:52 pm »
I had the manifold installed upside down.
