View full version: IDI Engine
  1. Installing the flywheel. Have a question....
  2. Thank You Guys! My AAZ Runs!!!!!
  3. Diesel conversion
  4. "Free" injection pumps mods
  5. powergains 1.9 AAZ
  6. 1.6 NA 1982 jetta with some duct tape
  7. vaccum pump install problems
  8. Timming belt issue
  9. lower rad support
  10. Changing out my old cluster for one with a TACH ( now have pics )
  11. Truckdoza Turbo Diesel Build Thread (Looooong)
  12. KKK K14 or Garret T2
  13. My first intercooler
  14. how much advance is to much???
  15. What turbo is this?
  16. Started my 1st IP Rebuild: Rusty Core? 3 Sided Bolt Tool? and Other questions.
  17. Question regarding engine block leak...
  18. Stock T3 Turbo.....
  19. T3 not soundin so good
  20. rear main seal
  21. Truckdoza is finished!
  22. 1.6N/A Crankshaft bolt
  23. valve marks in pistons ADVICE NEEDED PLEASE READ
  24. Electric gauge wiring
  25. my style oil spearator
  26. Synthetic or not?
  27. AAZ exhaust ? PICTURES ADDED
  28. replace head or try to fix? pics showing damage
  29. I need a head asap
  30. Guess what's wrong (charging issues)
  31. Vacuum pump and oil pump are binding
  32. Turbo Oil Supply Line Sprung a leak. Get new? Make New? Fix Leak? Get Used?
  33. Need advice: rebuild or trash 85 jetta
  34. Finally... she's finished.
  35. Crankcase breather discussion
  36. AAZ Cam belt cover
  37. weird fueling problem
  38. Cold Start Problem
  39. alright, its getting old...
  40. Alternator sepentine belt tool ?
  41. Alternator belt 1.9 AAZ ( non - A/C ) Serp setup
  42. Guys I need some help and advice
  43. second opinion... wire issue or oil issue?
  44. Tranny and brake help needed....
  45. New head install leaked coolant
  46. Almost together!
  47. Head gasket, studs, timing, etc.
  48. intercooler question
  49. removing shift knob
  50. how to turn idle down
