» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
k03 turbo rebuild question
1.5D cam in a 1.6TD mech head?
Exhaust tubing diameter for AAZ?
overheating question???
some pics of my mk1 project
Hard work pays off
Teh White Rabbit Build.
t3 waste gate can removal
Injector cleaner
Can't set injection pump timing with dial indicator
Can I use a VW 1.6TD crank and intermediate shaft in an 81 - 1.6D motor rebuild?
Alternator squeal after engine start
What happened to prothe?
aaz with a 92 tach reading to high
flex exhaust tubing
Can I put injection pump top with LDA off 1.9TD or 1.6TD onto a 1.9NA pump?
K24 Turbo Map
1.6 or AAZ gasket
AAZ oil consumption / overfill?
glove box light
yellow dot pump on a 1.6
Can an injector get to tappin?
For those with a Westach EGT gauge
engine overheat prevention alarm
im shaft pulley how u guys remove that with minimal tools?
1.6 td GT15 Question
Guide/suggestions for affordable mk1 n/a exhaust/dp/etc?
Crankshaft pulley ideas
1.6d to 1.6 ecodiesel
T3 on AAZ manifold question
Checking main cap installation
Exhaust Options
1.6td shift points
Turbo Oil Feed Line Question
AAZ valve cover upgrade ???
Where to get a vacuum pump?
need verification about replacing cam
k03 rotor assembly
1.9L TD AAZ into a 2.slow shell (SWAP) - MK3
My AAZ swap, some turbo connection questions, and a few others....
Automatic 1.6 TD
removing exhaust manifold in car
Can pressure plates be reused??
Changing clutch - out-put shaft came out of tranny
Clocking a VNT?
Resonator recomendations
can you blow a headgasket over night?
What's the name of that piece of plastic in the valve cover and what does it do?
water intrusion
2nd Ring Specs
