Author Topic: AAZ valve cover upgrade ???  (Read 6822 times)
February 11, 2010, 06:55:37 am
stewardc
« on: February 11, 2010, 06:55:37 am »
I have this now, but the search continues for something more unique for the old girl. What have you got?
Reply #1February 11, 2010, 04:39:02 pm
stewardc
Re: AAZ valve cover upgrade ???
« Reply #1 on: February 11, 2010, 04:39:02 pm »
Bump....anyone ????
Reply #2February 11, 2010, 05:27:53 pm
gnavs
  • 340
« Reply #2 on: February 11, 2010, 05:27:53 pm »
I love the G60 covers but I'm told they don't fit on AAZ's, is that correct?
Stewart, you're looks pretty good  :)
Reply #3February 11, 2010, 06:00:48 pm
truckinwagen
  • 1895
« Reply #3 on: February 11, 2010, 06:00:48 pm »
the G60 mounts with studs around the outside of the head like the 1.6 V/C does.
I dont think there is a better looking option that uses the three bolt hold down.
you could always drill and tap for the 1.6/gasser style studs around the perimeter, which would allow you to use a G60 or other aftermarket valve cover.
-Owen
83 Opel Kadett Diesel
Reply #4February 11, 2010, 06:47:14 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #4 on: February 11, 2010, 06:47:14 pm »
I have bead blasted my cover and plan on adding an emblem in a resin form and then powdercoating the whole thing, this will leave the resin alone, I'll tape it off ans paint it a different color.  I am still unsure of the color scheme though.  I have a broken oil cap, and need another one, any advice on pimping that?  I see that you have a MERC one that is chromed out, looks nice.  I have one of those on my 1.5 may just get another one for that and use that one on my aaz.
Kevin
Reply #5February 12, 2010, 07:10:27 pm
MoparEd
  • 37
« Reply #5 on: February 12, 2010, 07:10:27 pm »
Id like to put a newer style volkswagen engine cover over my aaz to be honest, dont know if it can be done and look right tho.  Good luck with your search
Reply #6February 12, 2010, 07:44:16 pm
« Reply #6 on: February 12, 2010, 07:44:16 pm »
uggg.....you mean one of those plastic things? Those are for people who are embarassed about their engine......
Reply #7February 13, 2010, 04:10:35 am
stewardc
« Reply #7 on: February 13, 2010, 04:10:35 am »
I agree, and, in my opinion, so is the stamped steel one......but, so far, no joy on finding a cool replacement.
Reply #8February 13, 2010, 06:22:09 am
« Reply #8 on: February 13, 2010, 06:22:09 am »
Have a machine shop custom make a billet aluminum one to your taste. A little cutting on a big chunk of Al and a good imagination *CASH* and you could have whatever you want :D
Reply #9February 13, 2010, 07:55:00 am
NintendoKD
  • 931
    • myspace page
« Reply #9 on: February 13, 2010, 07:55:00 am »
*CASH* is a luxury not all members can afford, I think that someone could still use the stock cover but somehow emboss, or put something on there.  I am making a resin emblem and putting it on mine, and sealing it to make it look like it was always there. 8)  simple easy project anyone can do it.  use a plasma cutter and a press and make any emblem design you want for cheap clean it up and emboss said beastie to the valve cover, you may want to heat up the valve cover by baking at 500 f for about 30 min and immediately move it to the press, will take a little coordination but nothing that the talented folks on here can't handle. 8)
Reply #10February 13, 2010, 09:32:17 am
« Reply #10 on: February 13, 2010, 09:32:17 am »
You and I are very similar when it comes to ideas like that. I can make about anything with some form of plastics. My old job I worked alot with urathanes, expoxies, and all sorts of stuff for castings. Your idea on adding a badge would be simple and look good, but I think the OP is looking for a little more...I could be wrong. It would be fun to make a valve cover for one of our engines out of Devcon or something similar with a complete custom top and steel inserts all around. Might be able to do carbon fiber over the stock one if you're into that kind of look.
Reply #11February 13, 2010, 09:38:47 am
stewardc
« Reply #11 on: February 13, 2010, 09:38:47 am »
Wow, carbon fiber...I never thought of that. Drape and bake.
Reply #12February 13, 2010, 10:07:01 am
NintendoKD
  • 931
    • myspace page
« Reply #12 on: February 13, 2010, 10:07:01 am »
cansomeone say reverse mold?  then you can make a C/F cover, no metal at all, now that would be a custom job, and look pretty badass, also you could use an emblem or something between the layers to give it a really classy look.
Reply #13February 13, 2010, 10:17:12 am
truckinwagen
  • 1895
« Reply #13 on: February 13, 2010, 10:17:12 am »
I would love a clear acrylic valve cover.
I have a friend going to school at the School of the Art Institute of Chicago, and he has access to a vacu-form machine.
I am tempted to clean up a valve cover and send it to him to make one out of acrylic, then you could see the cam spin!
-Owen
Reply #14February 13, 2010, 10:21:55 am
NintendoKD
  • 931
    • myspace page
« Reply #14 on: February 13, 2010, 10:21:55 am »
the oil would probably dye the acryllic, but I like the way you are thinkin. ;)
