Author Topic: 1.6 td GT15 Question  (Read 2771 times)
September 16, 2011, 04:54:01 am
fourstar
  • 16
« on: September 16, 2011, 04:54:01 am »
Hi!
I've got GT15 of a 1.9 td AAZ and I want it to put it on to my 1.6td, question is about wastegate actuator, it has two inlets, one is for boost coming from compressor and one for vacuum. Can I leave vacuum's inlet not connected(bleeding some pressure to air from actuator) and just connect boost inlet?? If I block vacuum's inlet wastegate kind of not want to work.
91 Golf Mk II GTD
Reply #1September 16, 2011, 08:54:43 am
Re: 1.6 td GT15 Question
« Reply #1 on: September 16, 2011, 08:54:43 am »
Hi!
sure its not a K03?
i didnt think the GT15 came till the TDI engine?
dont connect anything to the vacuum side.. leave it open to the atmosphere.
it was just to limit the boost below the wastegate settings.. emissions junk!
« Last Edit: September 16, 2011, 08:56:16 am by R.O.R-2.0 »
Reply #2September 17, 2011, 01:10:14 am
fourstar
  • 16
« Reply #2 on: September 17, 2011, 01:10:14 am »
At first I thought it was K03, but then I red the green plate on compressor's housing and it says it's GT15.
But when I try to blow some air trough actuator it comes out where vacuum should be connected is it normal or actuator is leaking?
Okay I will left vacuum side not connected and give it a try!
Thanks!
91 Golf Mk II GTD
Reply #3September 17, 2011, 10:08:08 am
« Reply #3 on: September 17, 2011, 10:08:08 am »
Thanks!
nope, that means the diaphgram is ripped inside the actuator. or else it has 2 pressure feeds, witch would be weird..
plug one side of the wastegate can, and see if it will operate the WG..
