» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
The quick resurrection and fuel mileage of a 1989 Jetta Diesel
Cold Weather WOW!
Need help- 1.6TD cooling hose NLA - alternate hose ?
81 Caddy Dying..
Best combination of Motor Mounts for a MKII
Where to purchase MK-1 Caddy Diesel Sending unit, hoses, and gravity valve?
Rust in 1 cylinder....
VNTs on TDIs
Need to turn down the smoke
Ideas wanted - AAZ Diesel stalling at idle
New engine..
35 psi boost and resultant running problems
do i need to check my egt's on a vanagon AAZ
replacing the intermediate shaft bearings
1.6 N/A actual performance testimonials!
Look at what I've been up to lately
Special socket for IDI injection pumps
G60 intake manifold
what, if anything, happens if you don't set max rpm stop on 1.6td pump?
SHCS for 11mm Head bolts?
Dumb Question: 1990 Jetta IDI
Identify T3 1.6TD turbo pump
just how ghetto.. that ghetto!
Poor hot starting.
'90 1.6NA into '77 Scirocco questions.
Engine wont start
mk2 instrument cluster circuitry for tach
injector leaking at the halves
mk2 cluster in a mk1?
MKII Vibration blues
IP Questions
Tacho question for the electronics gurus
Piss, got the head on and motor running...noticed a problem...
Horrible cold starts.
Fuel Filter Pre-Heater Delete
'Mild' gov mod?
Highway boost/Wastegate thinkin
Exhaust valve contact all four pistons! PICS ADDED
Safest way to remove fuel limiter pin? (And add an LDA to a N/A injection pump)
Rad fan stopped working after extending cranking
need help with a checklist for IP swap and headgasket work
cooling oil on a vanagon with AAZ
timing and cr
Vnt Blowing oil..... Still!
flycut head but nothing done to pre combustion chambers???
ARGH! AAZ LDA seal... In the UK...
My life is now plagued with stuck vanes! (VNT)
VNT Exhaust brake
Don't buy Sealed Power Intake Valves for AAZ
