View full version: IDI Engine
  1. Which one?
  2. Vacuum line replacement
  3. Cold Start Shaft Cover Seals in DGK126 Green?
  4. dissolving water ports in cylinder head (lots of pics)
  5. this turbo i have, let me show it to you. [56k, pull it.]
  6. serpentine setup, no power steering, possible?
  7. injectors return fuel lines. Size?
  8. 1.9L AAZ max fuel+more boost, much difference???
  9. 1.8 T to m-TDI?
  10. can a k14 compressor housing be rotated
  11. starting problems....
  12. Boost control
  13. noob questions
  14. New way to connect DP to turbo. No bolts, just V-band.
  15. How much blowby it too much?
  16. Budget buildup
  17. Mounting a VNT to an AAZ. Does this oil return look right?
  18. how fast can i go?
  19. buying a car run on bio diesel?
  20. fuel system HELP please
  21. AAZ specific main bearing help
  22. Connecting IP fuel hoses
  23. Start me up!
  24. How does the throttle cable thing go back together?
  25. no intercooler question
  26. ARP Sizes / Part Nos?
  27. Where to find 1.9 parts in the US
  28. New to the sight, got a question.
  29. Multiple solenoids on IP?
  30. best boost pin and spring for power without smoke
  31. Clutch Options
  32. ECOdiesel question
  33. Lighter flywheel
  34. Motor mount discussion
  35. Tiny-Tach
  36. fuel shutoff
  37. Swain tech group buy
  38. Water/alcohol injection system. Give me your opinion.
  39. 1.6 BOV Plug ???
  40. Bosch VE Injector pump mods. (diesel power march 2008)
  41. turbo upgrades
  42. Which of these turbos lying in my garage should I choose?
  43. Eccentric grind on GTD boost pin - normal?
  44. LDA Pin/Starwheel/Smoke Screw Pictoral And some Q's
  45. need some gear box advice
  46. Transmission compatability with 150HP + engines
  47. how are these numbers?
  48. AAZ intermediate shaft bearings
  49. 16v
  50. after rebuilding my pump, the car wont start
