Author Topic: starting problems....  (Read 1883 times)
February 25, 2008, 05:10:59 am
greasyscott
  • 1
« on: February 25, 2008, 05:10:59 am »
hey folks,
i am stuck.  i have an 81 diesel bunny that has been pulled from a field after sitting for 11 years and i can't get it to start.  here is what i have so far:
    new glow plugs with power to them.  it still won't fire with even with the block heater on
    stop solenoid clicks when i jumper it.
    fuel comes out of the injectors when they are opened slightly  fuel is brand new and coming from a clean can
    engine cranks and i can see the timing belt turn as it should
    i checked the oil level and it is good, when i remove the cap, it looks like there is some smoke in there
anything i should try before removing the injectors to see if fuel is spraying thru them?
also, what size socket is needed to turn the injectors?  a 22?
thanks for your help...
Reply #1February 25, 2008, 12:36:17 pm
« Reply #1 on: February 25, 2008, 12:36:17 pm »
any bubbles in the lines?  if there is any air in the lines chances are it won't start.
is it cranking over at a good speed? slow cranking isn't really good enough for an older diesel... plus the rings might be stuck?
i guess the last thing to check would be compression. (you can also check glow plugs while the injector is out... dont forget new heat shields)
