View full version: IDI Engine
  1. 1.6 n/a and 1.6 td crank
  2. probably a dumb idea, but......
  3. Will an intermediate shaft pulley from a 1.6 fit a 1.9 aaz?
  4. Replace engine or not? Newbe needs options.
  5. Head/ headgastet /cooling system questoin
  6. 1.6 performance mods
  7. What starters work on a 86 Golf Diesel 1.6 NA
  8. Sputter bearings
  9. 1.9td turbo swap
  10. Help!!Broke the electrical connection bolt on my 1.6 starter
  11. Pump question.
  12. Kolbenschmidt 1.6TD piston part #needed.
  13. cylinder head bolts
  14. 135bar instead of 155bar injectors in a 1.6TD?
  15. AAZ pistons anyone?
  16. Engine rebuild
  17. Mechanical and Hydraulic Cams
  18. No top end power, hesitation
  19. 1.6TD (CY) Intercooler upgrade....???
  20. Performance mods 1.9D 1Y?
  21. Thrust bearings 2pc vs. 6 pc.
  22. anoying rattle 8-(
  23. 1990 A2 non-turbo idle & running issues after fuel filte
  24. Exhaust Sound
  25. Franken glow plug/ control/ relay question
  26. So I added a boost controller. next step to add more power?
  27. 1.6 na injector pump rebuild instructions, advice?
  28. Boost pressure porblem Garrett T3 Mk2 1.6 TD
  29. New To The Diesel Crowd:Improving my 1.6TD
  30. Dave @ PP and my new exhaust/intercooler/air intake
  31. Rubber G60 VC gasket on 1.9?
  32. TD swap into my Caddy
  33. IDI main bearing cap failure
  34. Convert solid lifter head to hydraulic?
  35. 1.6 idi oil dipstick tube leak
  36. 93 vs. 97 AAZ
  37. What would cause this type of damage?
  38. junkyard turbo #4 blown, time for a proper turbo
  39. 1.6 L fuel injection pump leaking
  40. max Hp or quarter mile time/speed
  41. cooling system problem
  42. Carnage Pictures - loose bolt in bellhousing!
  43. 1.0mm and happy 8-))
  44. right or wrong?
  45. Head gasket question
  46. Oil cooling a 1.6TD?
  47. boost figures
  48. 1.6TD date code decode - help?
  49. need a new wastegate for my t3
  50. Is there a way to up boost without using a boost controller?
