Head gasket question
Topic: Head gasket question (Read 2487 times)
April 26, 2007, 09:08:08 pm
vixentd
April 26, 2007, 09:08:08 pm »
Just installed a head gasket on a 1990 1.6 diesel. Torqued to 35 lbs then 45 lbs then 1/4 turn with the head bolts. All i could do with a 25 inch bar.
Read the instructions on the gasket from German and it sounds like the want 50 nm and then two 90 degree turns. heat up and 90 degree more?
Can imagine this?
April 27, 2007, 04:48:44 am
Jetman
Newbie
April 27, 2007, 04:48:44 am »
Yep, autodata says,
Use new bolts
Step by step:
1. 45 Nm
2. 60 Nm
3. 180 deg.
4. run engine +50 C
5. 90 deg.
6. 1000km
7. 90 deg.
April 30, 2007, 01:57:46 pm
mtnsammy
April 30, 2007, 01:57:46 pm »
If it is hot it will turn. I used a cheater bar but it did tighten all the way.
May 01, 2007, 07:25:18 am
busguy71
User+
May 01, 2007, 07:25:18 am »
are these torque-to-yield bolts?
May 01, 2007, 08:00:20 am
May 01, 2007, 08:00:20 am »
I sure hope so, as ARP's just get torqued to 80 ft lbs with their lube.
