View full version: IDI Engine
  1. VE
  2. Intermediate shaft bearings.
  3. optimal exhaust size
  4. speratic functioning of fuel gauge
  5. 1.5 timing issues
  6. looking for a quick answer - stock 1.6td boost psi
  7. VW IDI Motorcycle
  8. where to buy - link request
  9. 1.6NA Headgasket Sporked, Rebuild Questions...
  10. Crankshaft seal (clutch end)
  11. Poor Mileage - Air bubbles and Internal Pressure
  12. serpentine setup
  13. Low/no oil pressure
  14. 1.6 Help needed (Rusted engine)
  15. Which trans has the tallest gears?
  16. intercooler intstall - pics too!
  17. Pre-lube electric pump.
  18. valve cover
  19. Relocated batteries
  20. Head gasket question
  21. My new 1.9TD projet :) Need advice
  22. New guy, Just bought a 1.6TD CL can i make it into a GTD?
  23. The Search function is close to useless! LDA Q
  24. intercoolers
  25. 1.9 TD real power
  26. need part number of 11mm pump head/plunger and 1.9 camplate
  27. Turbo'ing my NA 1.6d
  28. Repair for starter wire?
  29. turbo on an '81 n/a diesel...
  30. What Setups Are You Running?
  31. Timing Guage Set. Let's find the best one for a group buy.
  32. Santa Giles and his Bench Elves
  33. Question about black smoke and boost levels
  34. Automatic trannys
  35. AWD options.
  36. AAZ pump on 1.6l mech w/turbo?
  37. pump mods
  38. i've looked
  39. Piston spacer shim (internal IP Q)
  40. Tach and W terminal
  41. need help with shopping list
  42. Mounting fan on intercooler?
  43. Who makes Autolite Glow Plugs?
  44. LDA
  45. Will a transverse 1.6TD bolt right up to a Fox or 4000 trans
  46. my aaz fuel pump mods not woking, need help, please
  47. control cone
  48. EGT Question
  49. 1.9 water pump vs 1.6
  50. IP on Ebay, will it fit
