Author Topic: 93 vs. 97 AAZ  (Read 2580 times)
April 28, 2007, 07:36:02 pm
windsnob54
  • 15
93 vs. 97 AAZ
« on: April 28, 2007, 07:36:02 pm »
Hi,
i have an '82 vanagon with a 97 AAZ and a 93 td golf. the golf pump is kaput and needs to be resealed.
can i put an injector pump from 97 on a 93 without major work?
I know that in 97 they did something with the sproket.
next question...
can i put a JX 1.6 pump (from a euro vanagon td) on the 97 aaz without major work?
i know major work is pretty subjective but you know what i mean :)
...what is the opinion if this is good for performance in the 1.9td vanagon in conjunction with gtd injectors or not.
thanks!
Martin
Reply #1April 29, 2007, 09:27:34 pm
windsnob54
  • 15
93 vs. 97 AAZ
« Reply #1 on: April 29, 2007, 09:27:34 pm »
...c'mon someone help me out here, please.
are the 93 and 97 aaz  injection pumps interchangable?
thanks
Reply #2April 29, 2007, 09:33:55 pm
935racer
93 vs. 97 AAZ
« Reply #2 on: April 29, 2007, 09:33:55 pm »
Yes you can, but the sprockets for each type of pump need to stay with the original pump.
Reply #3May 03, 2007, 09:44:25 am
houseofdiesel
  • 210
93 vs. 97 AAZ
« Reply #3 on: May 03, 2007, 09:44:25 am »
You will have to change the mounting bracket that came with each pump in order to swap from one style to the next (where the pump mounts is a different size hole in each bracket). otherwise shouldn't matter.
The Vanagon pump good question, count the teeth on the pulleys, different timing belts...and throttle cable set up is different.
