» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
AGS trans vs ATH
A few Questions
New belt so WTF
Need some 1.9 AAZ Rebuild Advice
compressors the same on diesels v/ gas?
ABA AC alt bracket?
Possible to have a bad port on a Bosch VE pump?
Buying a Rabbit with timing problem
serpentine on the 1.6
B3 AAZ tech info
1.6TD Coolant hoses.
new build, need suggestions
'87 jetta 1.6td stock tire size?
resealed fuel pump problems
governor question
What other VW cars share the Golf/Rabbit 1.6 GTD gearbox/trans (code 4T)?
Timming belt too TIGHT!!!
Thinking about running a GT2560 (GT28r), any thoughts?
1.6td 5speed into a 92 auto gas Jetta..
Help wanted on 1980's 1,6 n/a turbokit
How much can pump wear affect timing?
reasons for and against using a 1.9head with the 1.6 bottom?
Need help with 1.6 No-Start
Performance Build Help??
German Dash cluster
cracks in the turbo housing
~My 91 GLI to 1.6TD conversion build up~
vacuum pump
I dont understand why?
other T3's drop into the factory tubine housing?
1.6TD performance downpipe??????
YESSSS!!!1!!11! It actually drives!!!!
Free Beer! (help with timing please)
K24/T-3 Turbo - anygood??
Double grommet installation-1981 rabbit
Clutch....
Is this pump any good for my 1.6gtd ???
Cleaning valve pockets
crankshaft scratches
i have a quick question.
my 92 ecodiesel headgasket doesnt have holes?????
GOVERNOR MOD
Mini Dyno Day - 1.6na '84 Jetta
Running it hard with more fuel/boost... Anyone going through glow plugs?
Clutch Upgrade
Cheater Bump
Solid Copper Head Gasket
Camshafts. Need some help.
How much boost on stock turbo'd AAZ?
D24T power! update...
