View full version: IDI Engine
  1. Starting a turbo build...Videos of it running :D
  2. Oil cooler - is it directional?
  3. Oil return Line.
  4. K14 Ecodiesel turbo into 82 Vanagon drain and wastegate clocking??
  5. Diesel in 93 Eurovan
  6. 81 Caddy needs windshield
  7. so will it work??
  8. HELP!!.. does anyone know how to time a 5cyl audi diesel???
  9. AAZ crank nose pics ???
  10. Yet another timing question, is my pump retarded?
  11. Timing vs starting
  12. who's got a picture of oil drain line setup for an AAZ Vanagon
  13. TDI flywheel/VR6 clutch (228mm) - AAZ Vanagon
  14. 1.6 D Build (or 1.6 TD conversion)
  15. Speedometer reads slow.
  16. Guess what's wrong with my motor..
  17. Is 81 Caddy's oil pressure warning system adequate?
  18. will this be ok?what to do?
  19. lopey idle, lots of gray smoke
  20. Mk2 engine mount discussion
  21. 1.9 AAZ engine mount angle (when it's not 50)
  22. 1.6 NA in a Caddy drivability
  23. 1.9 TD Starts, but won't run - Need help
  24. Oil port threads on back of AAZ head.
  25. Think this will buff out?
  26. K26 from a Mercedes.
  27. Quick Question - Which Timing Belt for AAZ head on 1.6TD block?
  28. Timing the IP with an indicator
  29. help me with this part numbers please
  30. IP plumbing questions
  31. Rabbit needs a new clutch.
  32. Exhaust gasket 85TD
  33. AAZ 3-bolt steel valve cover - gasket sealer or no?
  34. Photo upload test - please ignore
  35. Out of fuel & glow plugs
  36. Turbo boost question
  37. Kooky idea??? Using a distributor to trigger a tach signal...
  38. In bolt in the out bolt hole. Stupid question.
  39. Boost response?
  40. Silicone coolant hoses - AAZ in 82 Vanagon
  41. Biggest battery to fit my 81 Caddy?
  42. Electronic VNT control DIY
  43. What do I have and will it work??? (Turbo question)
  44. TDI transmission on IDI
  45. Radiator core support differences
  46. Injection pump bracket.
  47. Still need a one hole head gasket
  48. Trying to find a decent T25 turbo manifold.
  49. Loss of torque after Gov Mod.
  50. Would like to do vnt but some of the FAQ photos/links don't work.
