Author Topic: Oil port threads on back of AAZ head.  (Read 2612 times)
June 12, 2013, 08:09:46 pm
Jetmugg
  • 530
« on: June 12, 2013, 08:09:46 pm »
Can anyone tell me what the threads are for the oil port on the back of an AAZ head?  Are they 1/8 NPT, or 10mm x 1.0 pitch straight threads?
I'm having a little bit of an issue figuring out what kind of fitting (threads to AN fitting) to use at that location.
Steve.
Reply #1June 12, 2013, 08:33:45 pm
Gizmoman
  • 1301
Re: Oil port threads on back of AAZ head.
« Reply #1 on: June 12, 2013, 08:33:45 pm »
I don't know of any "oil ports" on the back of an AAZ head.
The only ports I am aware of (other than intake and exhaust), are both for water.
Reply #2June 12, 2013, 08:50:08 pm
Jetmugg
  • 530
« Reply #2 on: June 12, 2013, 08:50:08 pm »
You are not looking hard enough then....
I'm describing the "back" of the head as the end opposite the camshaft pulley (driver's side when installed in a US spec vehicle in transverse orientation).
After a little more measuring and test fitting, the threads are 10mm x 1.0.  I think that some folks will use 1/8 pipe, but the threads appear to be straight 10 x 1.0.
Steve.
Reply #3June 12, 2013, 08:51:55 pm
« Reply #3 on: June 12, 2013, 08:51:55 pm »
They are straight.
Reply #4June 13, 2013, 06:40:11 am
Gizmoman
  • 1301
« Reply #4 on: June 13, 2013, 06:40:11 am »
Got it - where the sensor is screwed in  :-[ DOH!
