View full version: IDI Engine
  1. 1.9 AAZ build questions
  2. What size turbo is on the Echo Diesel
  3. basic turbo question.
  4. First Startup issues....
  5. killer white smoke
  6. Just played with my boost pressure
  7. 1.9 AAZ Rebuild
  8. 81 caddy 1.6D no fuel from IP no elec. power
  9. AAZ into mk1 question
  10. Need turbo identification help!
  11. Just thought maybe some would like to know...
  12. Golf MK3 Speedo query/help
  13. 96 Passat TD AAZ not shutting of with key
  14. Ac Compressor questions..MKII & MKIII
  15. AAZ dies, now runs rough
  16. turbo for my mk2 aaz, what vehicles to get one from
  17. need pump advice
  18. rough running since the copper washers were changed.
  19. mercedes SD327 nozzles.
  20. Windage Tray Bolts
  21. Oil coolers?
  22. Removing downpipe-How difficult?
  23. CV Joint
  24. Can a tuned AAZ have about the same HP and torque output as.
  25. 1.6td 170hp 290nm powered by holset :)
  26. mk2 vs 8 point buck
  27. intermediate shaft seal
  28. wanted - flange for k14 turbo???
  29. Optimum Position for EGT Probe On Manifold
  30. Is my pump worn?
  31. Head/ rings / crankcase pressure??
  32. Garrett t25's, log manifolds...
  33. Smoke
  34. oil level up but on startup light is blinking
  35. Which piston ring?
  36. simple glow plug circuit?
  37. Help identifying a bad lifter
  38. my tach is reading low....but why???
  39. can I swap in a gasser radiator?
  40. anyone bought parts from Westportparts?
  41. The merits of proper tools
  42. valves (intake and exhaust )
  43. Governer mod on my 1.9
  44. no power in upper RPM **Now with Video.
  45. 85 Golf IP Timing
  46. valve spring compressor
  47. One last question on timing belt tension..
  48. 1.9 troubles
  49. Con rod bolt torque
  50. A small conclusion about a vnt15 NA, and some vids.
