Author Topic: Smoke  (Read 4433 times)
November 02, 2008, 03:13:34 am
Riverfurm
  • 122
Smoke
« on: November 02, 2008, 03:13:34 am »
Does black smoke under hard acceleration mean your making power or you have to much fuel or not enough air (boost). There is a fine line between black smoke and power, and with the mechanical IP it seems hard to find. Just trying to dial this engine in for best mileage and power.
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #1November 02, 2008, 04:30:14 am
Re: Smoke
« Reply #1 on: November 02, 2008, 04:30:14 am »
Quote from: "Riverfurm"
black smoke is just wasted fuel.  you want to clean that up by increasing the boost.  once you do that though you increase the chance for blowby and head gasket issues... but some run 20 psi no problem.
Reply #2November 02, 2008, 01:50:04 pm
Riverfurm
  • 122
Smoke
« Reply #2 on: November 02, 2008, 01:50:04 pm »
At 20 psi now with some smoke, like the power. About 2000 miles on a new motor.
Reply #3November 02, 2008, 03:05:05 pm
Smoke
« Reply #3 on: November 02, 2008, 03:05:05 pm »
hmmmm i would take it a bit easy on that thing if its new then... run it with 10 psi until you get at least 5k miles on it...
at 20 psi your car shouldn't have ANY smoke.  if you do, you will want to get an EGT gauge to make sure you don't cook the motor... would be a shame to ruin it!
did you get the 1.9 metal head gasket installed on it???
Reply #4November 03, 2008, 02:02:16 am
Riverfurm
  • 122
Smoke
« Reply #4 on: November 03, 2008, 02:02:16 am »
I put together allot of motors and ran them hard right from the get go. If it's going to have a problem let it happen in the beginning. Using cyl. head studs and an EGT gauge, temps run about 650 to 850 normal driving. Might see 1150-1200 on a long pull with 20 psi going up a hill. I can get rid of the smoke under hard accl. if I back off the smoke screw but there goes my power. I got an ideal for an intercooler that will be mounted under the hood with an electric fan. Don't have any room in front of the car due to AC condenser. Getting 38 MPG around town, might see 40 on the highway. I have the window sticker from when it was new for MPG, It states 38 MPG so I guess I am doing OK for mileage.
Reply #5November 03, 2008, 09:28:56 am
James8485
  • 223
Smoke
« Reply #5 on: November 03, 2008, 09:28:56 am »
i dont have a smoke screw for say but i run 20 PSI on my aaz and i pour the black smoke, my EGT gauge will climb to about 1000 in city but its really pouring out there, and on highway if im doing 100 and just mat it it pours as well i am running high boost so why so much smoke?
---------James--------
Reply #6November 03, 2008, 09:43:48 am
Smoke
« Reply #6 on: November 03, 2008, 09:43:48 am »
Quote from: "James8485"
is the EGT gauge pre-turbo???  you should probably adjust the pump to reduce the black smoke...
Reply #7November 03, 2008, 11:30:36 am
James8485
  • 223
Smoke
« Reply #7 on: November 03, 2008, 11:30:36 am »
problem with adjusting the pump is then i wont get as much fuel in my higher end speeds, its like i get way to much in normal / alittle heavy foot driving
but when i need it its there........kinda screwy if ya ask me!
Reply #8November 03, 2008, 12:07:32 pm
Riverfurm
  • 122
Smoke
« Reply #8 on: November 03, 2008, 12:07:32 pm »
My EGT probe is pre turbo. It does not make smoke intill 15 psi and high rpm, so it must be set about right. Plus I like the smoke factor fo people who like to follow to close.
Reply #9November 03, 2008, 12:30:58 pm
Smoke
« Reply #9 on: November 03, 2008, 12:30:58 pm »
Sounds like you have your answers then?
Reply #10November 03, 2008, 03:50:12 pm
Riverfurm
  • 122
Smoke
« Reply #10 on: November 03, 2008, 03:50:12 pm »
But why do you see diesels that drag race or do tractor pulls, pour out all that black smoke? More black smoke=more power? Or are they just over fueled?
Reply #11November 03, 2008, 03:57:00 pm
Smoke
« Reply #11 on: November 03, 2008, 03:57:00 pm »
more black smoke is more power, more fuel is wasted,  but at the same time more fuel is burned...  black smoke is actually partially burned fuel too.  when its white is when its just totally wasted.
Reply #12November 03, 2008, 04:01:23 pm
Jet A
  • 125
Smoke
« Reply #12 on: November 03, 2008, 04:01:23 pm »
Higher mass flow rate to spool the turbo. gets the temps up.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #13November 04, 2008, 09:04:17 am
Gearhead
  • 87
Smoke
« Reply #13 on: November 04, 2008, 09:04:17 am »
I've read that optimum AFR for power is beyond the "smoke limit" for diesels similar to the way that optimum AFR for power is beyond stoich on gassers.  I think I read that smoke becomes visible around 16:1 and power peaks around 14:1 or so.  Obviously, this changes depending on application and conditions.
That said, I try to keep my smoke at a minimum.  A light haze seems to give me decent power and mileage.  I'm trying to give diesels a better reputation.
'82 2 Door 1.6N/A :( Rabbit  '85 Cabrio project
Reply #14November 04, 2008, 10:28:32 am
TurboJ
  • 661
Smoke
« Reply #14 on: November 04, 2008, 10:28:32 am »
There's also one thing about diesel smoke that's nearly always ignored:
un-even air flow to different cylinders.
Take the stock VW IDI inlet manifold for example: it's about as bad as it gets. The two middle cylinders get noticeably more air flow than the outer ones.
This is one reason why it's nearly impossible to make power without smoking with stock inlet manifolds, while twin-plenum manifolds allow almost no smoke even on 200 hp + applications.
And everybody knows also what effect uneven AFR has on reliability...  :wink:
Jetta II 1.6 TD 'Project 200'
