View full version: IDI Engine
  1. i got a laugh out of this!
  2. AAZ head on an NA? :D
  3. Is this a K24 or a K14 turbo?
  4. Is there any way of getting more throttle travel?
  5. Metric Tap's Question/ Metric Bolts
  6. retorqueing 11mm headbolts
  7. dimensions of the governor
  8. 2.5" exhaust question
  9. Hydrodiesel: Turning max fuel down for better economy?
  10. Help with 1st start of AZZ/pump problems
  11. Ring Set Verification
  12. 1.6TD and 1.9TD pump question
  13. The 1991 Eco in FLA New pics and update
  14. AAZ hanging revs when warm, excessive smoke, excessive crank case pressure
  15. injector pump trubleshooting
  16. Turbo coupe T3 on a 1.6L IDI
  17. Machining squirters in block
  18. Propane Injection
  19. Storing an IP
  20. Increased fuel, less compression?
  21. HX25 on a aaz ?
  22. Can I run my IDI diesel on Natural gas?
  23. Break in question
  24. conversion questions
  25. Piston Protrusion Measurement
  26. Just shimmed the governor.... I have some Qs.
  27. I rescued a Rabbit from the junk pile....
  28. Milling 1.6 Hydro Head
  29. Save the crank I say!!!! Thoughts?
  30. manual boost controller fitting...
  31. blown head
  32. Going Gas to Diesel/Which Clutch Question??
  33. Help with front end oil seals
  34. intake manifold
  35. BOUGHT a '83 turbo jetta for parts...
  36. Removing fuel pump for rebuild, Timing?
  37. 1.6 td in a Syncro Van?
  38. help with throttle linkage for a vanagon aaz swap
  39. EG Temperatures?
  40. My '82 rabbit build
  41. Finally checked the code on my donor transmission
  42. Giles Pump - Current Price Quote $750
  43. Going against the grain
  44. Diesel supply/return line mix up
  45. source for aaz parts
  46. what nozzles are you using on your aaz
  47. Stock airbox = more black smoke
  48. Curious~ Have an extra engine and want to make more HP
  49. Diesel Newb with Passat B3 Wagon Tuning Project
  50. What is this connector on the breather hose?
