Author Topic: manual boost controller fitting...  (Read 12248 times)
April 02, 2011, 09:25:28 am
adi
« on: April 02, 2011, 09:25:28 am »
Where exactly do I need to fit one of these? I hear I have to cut a metal wastegate pipe (which is strange, normally it would tee stright into a vacuum hose between the turbo and intake manifold), if so, anyone got a picture of theirs fitted so I know exactly where it wants to go? Also when I fit a boost guage, which side of the boost controller do I want to be tee'ing that off to?
Reply #1April 02, 2011, 09:35:53 am
Re: manual boost controller fitting...
« Reply #1 on: April 02, 2011, 09:35:53 am »
you want boost pressure into one side of the boost controller, and plumb the other side of the boost controller to the wastegate, where it gets its signal from the intake manifold.
do you have a K24? i believe those are the only turbos with metal wastegate lines..
Reply #2April 02, 2011, 10:17:24 am
Fredrikkk
  • 155
« Reply #2 on: April 02, 2011, 10:17:24 am »
Let me lay it out for you:
You probably have a K14. If you have a K24, it's the same deal. You have to undo the banjo bolts that hold the metal wastegate line, and saw off the line so that there's about 5 cm on each side. Then you fit rubber vacuum hose over, and you fit your manual boost controller in the middle.
The boost gauge gets the signal from the pressure hose that goes to the LDA. Just tee off there and feed the line inside. I cut out the 12V in the console and fitted mine there; nice and "stock" and the needle is very stable too at idle.
As you can see I used fuel hose, and it leaked air like crazy, so I went over to a smaller vacuum line. Keep the boost at about 1 bar. If you want more, you'll need a 1.9 HG and stronger head bolts. :)
1991 VW Golf Pasadena GTD - Yeah, it's awesome.
Reply #3April 02, 2011, 10:47:08 am
« Reply #3 on: April 02, 2011, 10:47:08 am »
i would run it off the intake manifold bost signal if you were intercooled.. because there will be less boost after the intercooler..
so, say you set the controller to 15 psi, well when the turbo outlet sees 15 psi, the wastegate opens. but that may not be 15 psi in the intake manifold.. may be as little as 10 or 12 psi..
Reply #4April 02, 2011, 11:07:37 am
Fredrikkk
  • 155
« Reply #4 on: April 02, 2011, 11:07:37 am »
So my boost gauge is reading a little under 1 bar, and my engine is getting like 1.2 bar? I'm intercooled as well.
Reply #5April 02, 2011, 11:30:07 am
« Reply #5 on: April 02, 2011, 11:30:07 am »
wheres the gauge read from?
my boost gauge reads from the intake plenum, so i know whats going into my engine.. (pressure at the manifold is what your engine is receiving from the turbo)
im saying that in a less than perfect world, the boost at the outlet of the turbo can be slightly more than the actual boost in the intake manifold. there could be pressure drop from intercoolers, less than perfect boost piping, anything really..
Reply #6April 02, 2011, 11:35:41 am
adi
« Reply #6 on: April 02, 2011, 11:35:41 am »
Thanks for that picture of the MBC location, very helpful  :)
I could take a feed for the boost guage from the hose to the LDA (although I don't think mine has the LDA, it has a smoke screw on top of the pump), but are you saying it will be reading wrongly? Mine is also intercooled.
Reply #7April 02, 2011, 11:56:45 am
« Reply #7 on: April 02, 2011, 11:56:45 am »
not necessarily wrong, but  depending from where you get the boost signal, it will affect it.
i would take a boost signal from somewhere AFTER the intercooler, then it will be the most accurate.. theres really no wrong way to do it, i just think that its a better reading after the cooler..
Reply #8April 02, 2011, 12:33:45 pm
Fredrikkk
  • 155
« Reply #8 on: April 02, 2011, 12:33:45 pm »
My boost gauge reads from after the IC. So I've done it correctly then! Hooray :D
Adi, you're gonna be blown away by the extra boost!
Reply #9April 02, 2011, 07:19:15 pm
Powered by Spearco
  • 1203
« Reply #9 on: April 02, 2011, 07:19:15 pm »
Question, so using the boost ref. from the turbo to the top of the LDA instead of at the manifold when intercooled could result in fuel inrichment sooner?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10April 03, 2011, 02:56:39 am
adi
« Reply #10 on: April 03, 2011, 02:56:39 am »
So I up it to 1bar and then enjoy more smiles per gallon?  ;D
Reply #11April 03, 2011, 03:10:20 am
J Z
  • 42
    Sweden
« Reply #11 on: April 03, 2011, 03:10:20 am »
Then,  1.5 bar must be like  ;D + :)  smiles per gallon.  Right ??
'75 Volvo 242 D24 TIC
'90 Golf II 1,9 GTD
'91 Golf II 1,9 M-TDI
Reply #12April 03, 2011, 03:32:14 am
adi
« Reply #12 on: April 03, 2011, 03:32:14 am »
If I fit a larger front mounted intercooler, is it safe to run 1.5 bar on a K14?
Reply #13April 03, 2011, 03:41:19 am
Fredrikkk
  • 155
« Reply #13 on: April 03, 2011, 03:41:19 am »
Its efficiency range is 1-1.2 bar. After that it just blows hot air.. Plus your head gasket isn't made to last at 1.5 bar. ;)
Reply #14April 03, 2011, 03:47:40 am
adi
« Reply #14 on: April 03, 2011, 03:47:40 am »
1.2 bar it is then, what sort of BHP will that make?
