Author Topic: injector pump trubleshooting  (Read 1964 times)
April 08, 2011, 07:45:00 pm
playit
  • 16
« on: April 08, 2011, 07:45:00 pm »
I recently changed the timing belt and water pump on my 91 ecodiesel.
I did not time the pump as advised in the Bentley manual, I just wanted to get the car started and fine tune the pump by ear if needed.
when I started the car it ran with a low idle even with the cold start lever all the way out.
I ran the car around the yard a few times, stopping to add coolant, wile adding coolant the car sputtered and died. I then tried starting it several times with no luck. I started the troubleshooting process, I checked the fuel system, stop solenoid, glow plugs, compression...and so on. The car will start, but only if I floor the pedal and pat the gas to keep it running, it wont idle.
I also ran the pump right off a fuel can just to rule out a fuel filter or clogged fuel line.
I'm going to time the pump one more time with the dial indicator tomorrow.
any help would be much appreciated.
Thanks.
Tim B.
Reply #1April 08, 2011, 08:51:44 pm
Baron VonZeppelin
Re: injector pump trubleshooting
« Reply #1 on: April 08, 2011, 08:51:44 pm »
Go back and check through your initial timing parameters.
As in - Set timing mark at #1 cylinder TDC by the flywheel / bellhousing pointers.
Fit injection pump pulley lock. (1 tooth off on inj pump sprocket happens a lot to people on belt jobs - and they will usually still run - but sluggish)
Fit cam slide/lock. (This is usually the parameter that gets in trouble) It should just slip right in place. If not - adjust it accordingly. And use appropriate shims under the slide for a tight fit.
Normally after a belt job, you'll be within .05mm of the pre-existing injection timing setting one side or the other.
That is IF you had all parameters set right AND adjusted belt tensioner while the cam pulley was still loosened.
Re-check those parameters before you proceed with a dial indicator.
