View full version: IDI Engine
  1. Stronger Con Rods
  2. N/A to turbo questions
  3. My VNT on an NA build thread
  4. 1.9TD to 1.6TD swap ???
  5. Can I remove heatshield stud? its in the way turbo outlet!
  6. mk2 1.6TD gearbox question
  7. Any AAZ experts here?
  8. IP build
  9. Performance Ideas for a top end rebuild?
  10. will this 1.7 idea work?
  11. G60 valve cover on AAZ
  12. rebuilt engine value?
  13. 94 Golf AZZ Fuel Issues
  14. what car will hav this engine?
  15. Whats wrong with these pictures?
  16. overheating TD Vanagon
  17. pumps on other cars...need specs
  18. sat for a week, now hard start
  19. AAZ 1,9 TD - How to change the V-belt?
  20. Gasser Tacho on a DIESEL?
  21. 1.6 gtd engine code
  22. Polo 1.9aef to 1.6td
  23. Piston rings?
  24. Props to Hydraulic Supply In Langley, BC
  25. 1.6TD jetta. tach question
  26. parts swaping na and td cranks
  27. Retorque Q's
  28. Mk2 Air Conditioning in a Mk1?
  29. just want to check
  30. Can I use this to turbo a 1.5na?
  31. 1.6L waterpump and AC bracket
  32. is this gona make me go fast?
  33. Last year for the IDI Diesel
  34. Head Gasket bad, needs replacement
  35. swap 1.6td into mk3 diesel with crashed motor?
  36. help with vanagon disaster
  37. Intercooler question
  38. compound turbos
  39. what turbo do I have
  40. Torque setting for pump head.
  41. Will this work
  42. K-24 & T3?
  43. Adding fuel in 1.9
  44. Which turbo on the 2.1TD
  45. DTP injectors?
  46. Users/vendors with Etka?
  47. What k14 am I looking for?
  48. Is gear on end of 1.6 I.S. same as 1.9 I.S.?
  49. Just installed an oil pressure gauge
  50. Intercooler Plumbing Size
