Author Topic: 1989 Jetta 1.6 non-turbo, black smoke under load  (Read 2957 times)
April 11, 2008, 12:02:23 pm
briandownunda
« on: April 11, 2008, 12:02:23 pm »
My Jetta has approx. 125k miles on it, has been pretty well taken care of, seems to run pretty well, however, it does emit quite a bit more smoke than my old '81 rabbit used to....the mileage isn't quite as good either.
Any recommendations on what to do to reduce/eliminate the black smoke & also, perhaps what to check to improve the mileage ?
I get < 40MPG combined city/road.....I used to get up to 50MPG with similar driving style with my old '81 rabbit.
Thanks in advance !
Reply #1April 11, 2008, 12:15:23 pm
« Reply #1 on: April 11, 2008, 12:15:23 pm »
air filter is clean?
Reply #2April 11, 2008, 01:57:13 pm
vegfuel
  • 125
« Reply #2 on: April 11, 2008, 01:57:13 pm »
check you timing
1986 Golf WVO converted.
Reply #3April 11, 2008, 02:21:07 pm
foxracer1
  • 991
« Reply #3 on: April 11, 2008, 02:21:07 pm »
All of the above and check fuel filter.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4April 11, 2008, 02:56:57 pm
« Reply #4 on: April 11, 2008, 02:56:57 pm »
Quote from: "burn_your_money"
X2
Reply #5April 11, 2008, 08:39:42 pm
briandownunda
« Reply #5 on: April 11, 2008, 08:39:42 pm »
Thanks for all the replies, I will check all suggested and get back.....what about fuel injectors, if they are the originals, could they be causing the black smoke ?
Reply #6April 11, 2008, 11:17:44 pm
« Reply #6 on: April 11, 2008, 11:17:44 pm »
definitely
Reply #7April 18, 2008, 01:20:41 pm
briandownunda
« Reply #7 on: April 18, 2008, 01:20:41 pm »
I've replaced the air filter, but that didn't really help.  If I remove the fuel injectors, how can I tell if they are bad, vs. just need cleaning ?
