View full version: IDI Engine
  1. Need advice on my home built commuter. 1.6TD or MC power
  2. Interesting pics
  3. New owner of a 1985 turbo diesel Jetta
  4. NA to TD Conversion?
  5. one hole vs two hole head gasket ?
  6. Cheap Timing Belt/Tensioner Horror Stories?
  7. rpm question
  8. 1991 2 door TD how rare?
  9. Anyone in Toronto area with a CAM locking tool?
  10. Power steering pump rebuild?
  11. comparrison
  12. 11mm bolts for 1.9l head?
  13. Aligning spline on throttle assembly
  14. Diesel tach/ Diesel alternator!!
  15. overtightened belt VS. premature IP bushing failure
  16. bi turbo 1.9td?
  17. aaz 97 k03 staight turbo swap
  18. My first post
  19. to rebuild my mech head, or get a reman?
  20. Crank sprocket torque setting 1.6 GTD?
  21. replacing oil pump - questions!
  22. 1.6na
  23. Cold Cold Starts
  24. What type of oil to use?
  25. Benefits of Gasser Intake on 1.6td
  26. new 1.6 injectors and nozzles in 1.9 aaz - OK?
  27. EcoDiesel Air Filter OE Part #???
  28. 1.9LTD Burning oil problem, no one can fiqure it out!
  29. Where to buy 1.6 Ecodiesel Rebuild Kits
  30. head stud service bulletin?
  31. AAZ - Losing coolant when cold
  32. How does new engine just purchased (ABL) compare to AAZ?
  33. Hard starting after sitting for the night, rough cold idle
  34. How to check glow plugs?
  35. To soot or not to soot
  36. crank wear sleeve?
  37. Turbo converted 1,9d Skoda Pickup runs 13,96 @ the 1/4 mile
  38. bad AAZ update
  39. Can I use this Audi block?
  40. Valve adjusting
  41. Intercharger... anyone heard of this?
  42. Starting Issues - a new one
  43. better valve cover gasket for 1.9 NA
  44. Oil - Delo 15W40 - Really that big of a no no?
  45. Cold weather HARD/No start 1.6TD
  46. Ebay 1.9 head
  47. '02 TDI has a vnt-17?
  48. really long diesel oil filter?
  49. pump advancement for 1.6 na
  50. ac removal.
