Author Topic: really long diesel oil filter?  (Read 3376 times)
November 16, 2007, 06:17:54 pm
the4ork
  • 331
« on: November 16, 2007, 06:17:54 pm »
i bought one a while back but all i can find now is the short regular style ones that the gasser engines have... maybe i got the wrong one before but it was like almost twice as long...
i'd like to get another one like that for my diesel AND my 1.8t :P
Reply #1November 16, 2007, 06:48:52 pm
Black Smokin' Diesel
  • 656
Re: really long diesel oil filter?
« Reply #1 on: November 16, 2007, 06:48:52 pm »
Doesn't the 1.8T use cartridge type filter?
Reply #2November 16, 2007, 08:52:52 pm
diffdude
  • 39
« Reply #2 on: November 16, 2007, 08:52:52 pm »
1988 cabriolet gasser.Thats what i use.
81 caddy 1.6 td, 2.5" turbo back, snow performance water/meth injection, and all the other usual mods.
Reply #3November 17, 2007, 06:43:05 am
bert
  • 423
« Reply #3 on: November 17, 2007, 06:43:05 am »
I use the volvo 6 cylinder diesel oil filters,loads bigger,same internals but more paper media inside. they are found on vw engined volvo 740 diesels in the uk  :wink:
Bert
Reply #4November 17, 2007, 06:45:36 am
ELVIS
  • 51
« Reply #4 on: November 17, 2007, 06:45:36 am »
1.6td filter from a T3/T25/Vanagon/whatever you call it where you live  :D
Reply #5November 17, 2007, 06:36:03 pm
dokarex
  • 61
« Reply #5 on: November 17, 2007, 06:36:03 pm »
o to napa and et the proper mann or mahle filters I find them much better than fram or napa. If you need to crossmatch the numbers at your auto parts store the fram number is 3569
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #6November 17, 2007, 08:52:49 pm
« Reply #6 on: November 17, 2007, 08:52:49 pm »
i would never buy fram they are absolute ***, i like the napa gold filters alot, they look better than the factory mann filters side by side.  do larger filters likethe volvo one fit on mk1s?  the stock onebarely has any room
Reply #7November 18, 2007, 01:36:07 pm
« Reply #7 on: November 18, 2007, 01:36:07 pm »
or switch to amsoil EA fiters.  more expensive but filter much more.  couple that with a bypass filter and you're oil will stay super clean!
Reply #8November 28, 2007, 03:00:52 pm
boostin
  • 17
filters
« Reply #8 on: November 28, 2007, 03:00:52 pm »
the napa gold series are made by WIX filters, for media sq/in and density (micron) rating, the are difficult to beat.... and one of my favorite parts, they are possibly the best value....check out fleetfilters.com
89 A2 Jetta restored to mostly original/stock
01 A4 Jetta 133000 w/lots of mod's
84 D50 Mighty Max P/U rice smoker
79 HOT Trans AM, Bandit look-a-like
73 F250  428 CJ  (update.. CJ has left the building)
there are more...
