» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
VNT actuator question
Looking for place to buy ARP studs/bolts....
IP Bearing tolerance
Building 1.6 TD engine for power
boost comes at redline...doesent peak
thermostatic block heater
How to check for sure if my starter is gone...
What tools or methods are used for tightening the Crankshaft
New Giles pump & Passenger downpipe
Q's on an IDI engine you may, or may not, know
Boost pin modification!
Boosting a 1.5L N/A Dasher
LDA from another bosch pump
Injector Lines Leaking.... (Ground ? as well)
Some IDI questions.
93 Pump Timing
Another Giles pump install
Any harm in adding an intercooler?
intercooler on ebaygum
Cold Weatrher Starting!
Turbo Size?
1.6 gtd rebuild
Gasser Intake
finally the work has started!
PICTURES
what's this pump for (generator)
Removing intercooler on 1600 td
description/pics of 1.6TD pump to show fuel screws?
Source for NEW Injection Pumps for '84 Rabbit - Non-turbo
Intercooler sizing?
why my idle changed after power mods?
Changing a Vanagon 1.6 n/a to 1.6TD and 5 speed tranny
Lift Pump for 1.9TD
Custom Intake
Wires and plug on turbo?
turbo question
Mk1 tach install (Dakota Digital)
Conversion Q
will they fit?
LDA pivot pin
would a turbo off of a 87 saab 9000 be an option?
Replacing bolt in 1.9
READ Christmas
14mm head/plunger
Cam options
Audi 5 Cylinder Timing
Too bad these wouldn't fit
Electric choke on new injection pump?
Is it worth converting 1.6 NA to turbo
1982 Rabbit pick up project
