Author Topic: Boost pin modification!  (Read 13003 times)
January 05, 2007, 08:46:24 am
g-spec
  • 289
« on: January 05, 2007, 08:46:24 am »
Since all the 1.6TD's at my local junk are all stripped of boost pins I'm thinking of using my friends machine shop to modify the the stock 1.9IDI pin.....and i was wondering if anyone has any pics or pointers on where I should start removing material and where to stop....and maybe at what angle???
any comments appreciated!!
thanks
Michal
Reply #1January 05, 2007, 11:44:33 am
insdtanoodles
  • 148
« Reply #1 on: January 05, 2007, 11:44:33 am »
I am intersted in this as well, can throw mine onto my surface grinder at work and have some fun with it.
1996 vw jetta AAZ
Reply #2January 05, 2007, 12:05:10 pm
bert
  • 423
« Reply #2 on: January 05, 2007, 12:05:10 pm »
I have done a 1.9 pin with exellent results
First,look on the pin where the feeler has been running,to get an idea of how far down the pin to grind.
If you look at the pin from the side the taper starts to come on then flats off again,i carried the taper on at the same angle for about 12mm to cover the pin stroke, polished the surface up with emery cloth and light oil and voilia fast as hell!!
Bert
Reply #3January 05, 2007, 12:54:39 pm
insdtanoodles
  • 148
« Reply #3 on: January 05, 2007, 12:54:39 pm »
Quote from: bert
Bert
I like the voilia fast as hell, how has your clutch stood up to all the new power?
1996 vw jetta AAZ
Reply #4January 05, 2007, 12:59:27 pm
bert
  • 423
« Reply #4 on: January 05, 2007, 12:59:27 pm »
Hi,i put a new LUK 210mm clutch in when i fitted the engine and its fine,handles power easy,and it really is quick,
Bert
Reply #5January 05, 2007, 01:49:53 pm
g-spec
  • 289
« Reply #5 on: January 05, 2007, 01:49:53 pm »
How deep into the pin should i grind??? and what about the slope???
Reply #6January 05, 2007, 02:06:49 pm
bert
  • 423
« Reply #6 on: January 05, 2007, 02:06:49 pm »
the existing slope is there but only runs for a few mm,carry the slope on at the same angle whats there now, for about 12mm
Bert
Reply #7January 05, 2007, 02:16:27 pm
carrizog60
  • 978
« Reply #7 on: January 05, 2007, 02:16:27 pm »
and pics for the dumbs?(like melol)
Portugal
Reply #8January 05, 2007, 02:52:23 pm
« Reply #8 on: January 05, 2007, 02:52:23 pm »
yeah i would just modify a 1.9 pin, infact i would like to pick one up to modify for on my jetta, you can make a longer deeper taper with a 1.9 pin than with a modefied 1.6 pin
Reply #9January 05, 2007, 02:57:55 pm
bert
  • 423
« Reply #9 on: January 05, 2007, 02:57:55 pm »
Bert
Reply #10January 05, 2007, 03:03:08 pm
carrizog60
  • 978
« Reply #10 on: January 05, 2007, 03:03:08 pm »
is this pic correct?
i think the cone shape is upsidedown.... :?:
Portugal
Reply #11January 05, 2007, 11:34:58 pm
hillfolk'r
  • 1532
« Reply #11 on: January 05, 2007, 11:34:58 pm »
ah it helps,but its not a huge power increase
i ground the side that  was for more fuel anyways,and left the rest stock,so it can be set back if i want
lean setting
rich setting
i used a dremel  with a cutoff wheel to shape it ,then  i  used some sandpaper on the dremel to polish where the pin rides to clean up the grinding marks
Throttle cables ftw
Reply #12January 07, 2007, 08:19:41 am
Tintin
  • 1279
« Reply #12 on: January 07, 2007, 08:19:41 am »
You can modify the boost pin of AAZ with a die grinder and cutter wheel, or you makes news of it at your friend machine shop, it's easy.
I make a couple of them the last summer.
Reply #13January 07, 2007, 08:52:22 am
« Reply #13 on: January 07, 2007, 08:52:22 am »
it looks like you made yours with a longer slope and alot more agressive?  how doe these work compared to stock?
Reply #14January 07, 2007, 09:13:33 am
Tintin
  • 1279
« Reply #14 on: January 07, 2007, 09:13:33 am »
It is an illusion, the slope is same longor as that of origin.
I made a centered machinage, therefore can imports the position of the pin, that changes anything.
These pin will seek the maximum of travel of the feeler finger, the only adjustment is with the adjustment screw in the center of top cover. (increase or decrease fuel under boost)
